Thread: Help with a Build
- Mar 2007
- Los Angeles, CA
- 614
"What do you think the approx build cost would be?"
How long is a piece of string?
But seriously, I'd give Frank at Prodigy (https://www.pro-touring.com/forum/member.php?u=149) a call, as he's pretty generous with his time and expertise, or join the Thursday night chats here. There are so many variables (doing the work yourself vs. farming it out, locating the parts, getting the parts, getting the parts to work together, troubleshooting, changing your mind, etc., etc.), that it may be best to come up with a budget for how much you can spend, double or triple it, then try to build the best car you can within those constraints.
Buying a complete car is almost always cheaper than building it, so figure out how much you want to be involved in the build process and buy accordingly.
"all I need to do is the drivetrain, brakes, & wheels."
That is the right approach to take. Just keep that perspective, as "just" drivetrain, brakes, wheels and suspension can take a while.
Good luck!
