    Thread: Ls2 question
      Vallejo, California
      Ls2 question
      I was told that a Ls2, say out of a '06 GTO, originally equipped with an automatic trans, the crank is not drilled for the pilot bearing for a manual trans. Is there any truth to this and if so what are the fixes?
      Alex Johnson
      '69 Nova 350/TH350
      '63 Nova 305/TH350 (The wife's project)
      '76 Suburban 1/2 ton 454/th400 2wd (SOLD)
      '74 C10 Fleetside 350/TH350 (SOLD)
      '72 Buick Skylark 350/th350 (SOLD)
      Felton, DE
      I've never heard of that.... I've never really looked but ive bought engines that were from autos and put manuals behind them, no issues. Ive never heard of any ls1 cranks being different because of a pilot bearing. The only difference in any crank i know of is the LS4 crank which is 13mm shorter on the front and 3mm shorter on the rear.
      The pilot bearing isnt pressed into the flywheel? I thoguht it was. I cant remember now its been a while since i had my trans off. I know that you CANNOT use the grease/wet bread method to get it out. there is a freeze plug directly behind the pilot bearing and you WILL push the freeze plug into the block.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by larknut View Post
      since those cars could be had with a six speed or auto trans I doubt they'd spec different cranks for the two, wouldn't make sense.
      Jody
      Vallejo, California
      Quote Originally Posted by camcojb View Post
      Jody
      I was thinking the same thing but I don't know much about a ny of the LS motors.
      Thanks to you both for your help!
      Alex Johnson
      '69 Nova 350/TH350
      I cant imagine that its true. I have a truck 6.0 that you could not get with a manual and the pilot bearing went right in.
      Apr 2007
      Surprise, Az
      i got a crate ls2 and it worked with my tremec just fine
      1970 NOVA..Ls2/Tko..Speedtech/Chicayne, Alston Glink
      Chuck D.
