    Results 1 to 11 of 11
      Jan 2009
      67 camaro, need help going to discs
      Hey guys, I have a 67 RS camaro convertible, all drums...Ive been reading a lot but it's a lot to take in at once, so can someone put me in the right direction? Dont want to spend HUGE money but looking for a complete kit to change to discs, all four corners. Any help is appreciated.
      Jul 2007
      Tracy, CA.
      Paging Mr. Frank....
      Call Prodigy Customs, they are a sponsor here!
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Boise, ID
      Frank at Prodigy is great! He has helped me with my Camaro a few times...however, I went with Noel at Touring Classics for my brakes...Corvette based, buy parts at any flap and very easy instructions..13 inch up front and 12 in the back...easy installation and easy park brake hook up....make sure you plan your wheels at the same time....those big brakes take up lots of room!!
      Michigan
      Yup -- first step is going to be to sort out what wheels you will be running. 15" wheels are limited in terms of what size rotors you can package. 16's are a little less limited. Many 17" wheels will package bigger brake upgrades.
      Net thing you need to ask yourself is -- what do you want out of your disc conversion? Does it need to look really good (typically a big brake upgrade) Stop repeatedly at speed (road race, autocross, canyon carving?) or just serve you in basic drive/cruise...
      Aug 2003
      We have a factory style kit that does 4 wheel disc using a original style set up front in larger 11" size and does the rear in 11" later GM style. The complete kit front and rear, including all hoses, ebrake cables, booster and master is only $1200!
      Want a bit more, we have ProdigyCustoms Total Car G Machine Brake Packages featuring Wilwood brakes starting at only $1850 for the entire kit including all braided lines, E brake cables, master, prop valve, bal,bla, bla.
      Feel free to call and discuss
      Aug 2003
      Here is some information on our Total Car 4 Whl Disc Brake Conversion Kit
      Prodigy Customs presents our Total Car Disc Brake Conversion Package for F-Body 1967-69, A-body 1964-72, This complete kit provides everything you need to convert yout orinigal drum / drum set up to 4 wheel factory style disc brakes at a killer deal. For only $1000 you get....................
      Complete Stock Height Kit Includes 11" Rotors, Loaded Large GM Calipers, Caliper Brackets, Backing Plates, Stock Height Spindles, Hoses with Banjo Bolts, Vacuum Hose with Intake Manifold Fittings, Bearings, Seals, Dust Caps, Spindle Nuts, Spindle Washers, all Hardware, Cast Iron Master Cylinder, Brass Proportioning Valve Kit and a Power Brake Booster.
      Complete Rear Disc Kit Includes GM Rotors, Loaded Large GM Calipers, Caliper Brackets & Spacers, Bracket Hardware, Flex Hoses & Brackets, Emergency Brake Cables.
      These kits are in stock.
      For more information email [email protected] or call Frank at four zero seven 832 1752
      Dec 2008
      Rapid City, SD
      Hi Frank,
      Would this kit work with my 9" ford rearend? It isn't built yet, still waiting on wheel delivery to get final measurements. Also, I'm assuming since it includes emergency brake cables it has emergency brakes on the rear?
      Todd F
      Apr 2007
      Utah
      I just wrote a eHow on my disc brake conversion on my 68'. I don't know how involved you want to be in your conversion. I did mine myself. Total cost is about the same as some lower level conversion. If you have any questions on how I did mine. Please feel free to email or pm me.
      Sam
      http://www.ehow.com/how_4768504_disc...en-camaro.html
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
      Jonesboro, Arkansas
      Quote Originally Posted by ProdigyCustoms View Post
      For the money, and if you can't or don't want to spend the extra money for the top dollar brakes, you can't go wrong with this setup. I've seen these other places for a few hundred dollars more. I think I'd give Frank a call. Many people have use Prodigy and I don't think there's been one negative thing to say about them.
      Carl Wilson
      New Orleans, La
      I used them for a set of wilwoods front and rear on my 69 camaro, and could not be happier. I even called and spoke to frank to pick his brain and he had no problem answering any questions I had about the conversion.
      Jul 2007
      Tracy, CA.
      What happened to the OP? This thread is approaching a month old!
      Steve Martin
      67 Camaro RS
      66 Chevelle
