Thread: ALL T56 trans the same ??
01-17-2009 #1
- Mar 2006
- 12
what is the differance betweeen all the T56 , camero, mustang ,and viper , can you put a gm belhouse on a mustang T56? are they interchangeable ? I know guys use vipers on gms can you put a ford behind a gm , ?? which one is the best ??
01-19-2009 #2http://en.wikipedia.org/wiki/Borg-Wa...6_transmission
There are a lot of information easily found already out there. There is a ton of variation in the T56 transmission just for the Camaro much less Corvettes, Vipers, Mustangs, Astin Martins, Caddy CTS-Vs.
If you are serious about getting one for whatever your project, do some good research. If your wanting to put a T56 behind an old GM block (small or big), the easiest path will be the LT1 T56 from a 93-97 Camaro.
If your trying to get a Mustang T56 behind a GM engine, you need to take into consideration the input shaft length and spline count more than anything. I don't know if it's done very often.
01-19-2009 #3
