Results 1 to 17 of 17
Thread: Vari-shock problem
01-13-2009 #1
Vari-shock problem
So I found this problem today, it looks as though the shock bottomed out and the upper eye lock nut cracked the " closer nut " . Just prior to RTTH I found this shock had lost fluid due to the nut coming loose. It was sent out and repaired and does not seem to have lost any fluid.
The Vari-shock has 4" of total travel and I had the car setup with the 9" spring gland nut brought up to take out any slack. The car has an LS1 and is running 550 lb springs. I'm debating on going with a higher rate spring, and will be installing a rear sway-bar.
Has anyone run into this type of situation?
I need to correct this!!!!
Matt
01-14-2009 #2Ok, I need to address this situation I have with my car. The Chassisworks front subframe has no suspension bump-stops.
I'm debating on how to move forward and would appreciate any ideas from suspension guru's on what they suggest.
1. I'm thinking I need a higher rate spring.
2. I can adjust the front ride height up, prefer not to.
( I had the spring 550 lb set-up snug no compression )
3. I will be adding a 3/4" solid rear anti-roll bar to the Quadra-link.
4. Add bump stops to the bottom of the sub, my concern is in that position can it cause the lower a-arm to be tweaked.
I guess my first concern is preventing the shocks from becoming damaged again. Once that is addressed then I can proceed with other changes. Oh this car will be run hard on a road course and driven on HRPT long haul.Matt
01-14-2009 #3
