    Thread: Racepak Dash
      Mansfield Texas
      Racepak Dash
      Any opinions on these. Thinking of doing this in place of dash gauges. Going with a LS2 setup
      Jul 2001
      Calgary, AB
      The IQ3 setup is awesome and should be a straight forward plugin with the LS2 depending on the harness. With the MEFI4 MSD harness you need an adapter to go from the OBD pigtail to the CANBUS as well as a CANBUS adapter to convert the data. With the MEFI4 harness there is also an addition that you can get to incorporate oil pressure and temperature as well as fuel pressure. The logging abilities are out of this world and have a ton of potential. I'm working on tying in wideband O2 now and with the MSD harness this will feed back into the ECU.
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      I have a thread on open discussions about 67'-68' dash inserts for racepack. The racepack display is awesome & the logger like James has is totally badass! You can input & display enough s#!t to satisfy anyone.
      What kind of car are you doing?
      Peter
      FL and Calif.
      I would be intrested too if Racepack could be "pluged in" to gms LSx controller kit. Lets hope they would see the market here.
