      Feb 2007
      Plano
      ARP Flywheel Bolt torque
      Does anyone know the ARP Flywheel Bolt torque specs(330-2802)? Their website is ambiguous about it. Should I go with OEM specs?...Basic question but it is going to hold my entire weekend!!
      69 Camaro LS1 T-56, Corn is for making bourbon
      CHICAGO SUBURBS
      O E M specs are fine.
      Frank B. 1968 Camaro 355 Procharged 6 speed. 1983 V8 S10. 1984 Monte Carlo Magnusen Charged iron 6.0. Plus a few other junkers!
      May 2006
      Wa State.
      It is not an oem bolt you will want the right torque spec for it from the manufacturer.
      Its a stronger bolt you are going to need more torque to get proper bolt stretch.
      Call the manufacturer.
      -Ed Nelson
      1967 Firebird.......
      1970 Corvette. -Sold
      Central CA USA
      I have 350-2802 which is the same diameter and thread but it's the Pro series, there was a note in the package,- with their special lube, torque to 75 ft lbs, without their lube it's 115! I'd call them to be sure for your specific part number.
      David
      Feb 2007
      Plano
      Thanks for the responses.. turns out it was 60lbs with ARP lube and 75Lbs with 30wt oil...
