Thread: 454 bbc
01-09-2009 #1
454 bbc
I am new to the chevy world of engines.
So please the GEN IV BBC builders out there, I need some pointers…
A little info:
I got a real sour deal when the machine shop I took my motor to did a lot of work to my parts that I did not ask for, then proceeded to charge me for it. I was told “come pay for it, or I will be forced to sell the parts to pay for my labor..”
Anyways, it’s a 78-90 2 bolt block casting #14015445, and 781 casting heads.
I was told the closed chamber 396 heads on the motor (were swapped by previous owner of vehicle) did not flow well, and I needed 409, or 781 castings.
Ok so I get my parts back. I won’t mention the money I had to spend, but the block is tapped, deburred, align honed mains, surfaced block square with BHJ index fixture, bored and honed with torque plates .030 over, platue honed cylinders, cam bearings installed, and glass beaded/magnafluxed.
The first set of heads, the closed chamber 396 heads (3856206....65-66...oval..CLOSED..396, 97cc chamber) heads were cleaned, magnafluxed and taken apart, guides pressed out.
The second pair (336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports) were cleaned, magnafluxed, guides pressed out. That’s it, nothing else.
I have built many Fords, no Chevy’s. I need some advise on anything I would learn from years of chevy building. What to look for, secrets etc.
I need all the oil gallery plugs identified also so I make sure I get them all plugged up.
Any help is appreciated.
To give you an idea, I’m using the 268h comp cams top end kit with springs, 2.19 & 1.88 valves, Edelbrock Performer 2.0 intake, edelbrock 750 electric choke, 1 ¾ block hugger headers, .200 dome pistons (9.2-5:1, depending on actual head and head gasket cc’s)
400 turbo with small stall (towing convertor) and this is all in my 1 ton crew cab dually.
The truck is a tow vehicle for our toys, and friends. It is in the process now of getting its air ride and big lowering job.
Ok sorry for writing a book, but I appreciate any help and suggestions.
...life is too short, live for today, tomorrow isn't guaranteed
