    Results 1 to 12 of 12
      Cumberland, Maryland
      Roller cams and Distributor Gears
      So who hear really knows when what is right?
      Apparently I have an 8620 cam and can "only run a bronze gear". My problem with this is that the car is a street car. And I was mistakenly shipped a billet roller(yay...but issues). Specs and part numbers are damn near identical .
      So when does one run which type of gear?
      GM runs a melonized steel gear in there crate roller engines correct? I assume they aren't 8620 cores though, but a softer alloy.
      Bronze gears apparently wear, how many miles can one expect to get out of a bronze gear?
      Composite gears. What is the failure mode here? Total destruction? Do they not wear, but instantly disintegrate? Do they tend to last? These things cost as much as my distributor did.
      Other options?
      How about pushrods? Bronze tipped, do they last in this application? Ceramic tipped, same question, who makes these? Roller...wallet says "no".
      Sep 2002
      San Jose, CA
      With a billet roller you generally do need a non-stock gear.
      I've never heard of a composite gear failing when something else didn't go first. That would be my choice
      Just call me Brett
      Oct 2007
      central, KY
      billet cam = composite gear...period..
      - Mark
      67' RS Camaro - 468/476hp, polished, show car
      68' Camaro drag car-507/752hp,-13.1:1, only 241 miles
      79' TransAm- 540/763hp, Dave Monday custom built chasis,pump gas-10.2:1, LSM,CFS,Callies,AFR
      80' Z/28- all original, black w/ red stripes, 2nd owner, loaded, all paperwork - excellent driver
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      I've used the composite with good success. I have seen the bronze gears wear very badly and quikly.
      Okay thus far the composite gear seems to be the go to piece, figured as much on this board full of "ballaz". Anybody have a brand preference? Part numbers?
      How about for the fuel pump pushrod? Is the bronze tip okay, or are you folks going to also try to convince me that my only choice is a roller pushrod?LOL
      May 2004
      Dallas, TX
      I ran a bronze gear for about 4k miles when I noticed significant wear. I replaced it with a comp one and have about 2k miles on it. I am going to pull the carb for some work soon...I think I will pull the dist at the same time and check the comp gear.
      Ive used solid rollers in my Pontiacs on the street for a long time. Prior to the availability of the composite gears, bronze was the only option. Even in a limited use, I changed bronze gears at least once, and sometimes twice a year. I was using the bigger 80# oil pump, so that certainly didnt help the situation.
      The last motor I had did use a composite. That gear went over 3 years of limited use and showed NO wear whatsoever. Conclusion?
      Billet solid roller = Composite distributor gear.
      Set the endplay at .012" with hardened shims and forget it.
      Comp Cams composite.
      Jan 2007
      CT
      Composite is the way to fly.... I have run on on the street for 3+ years with no issue. I inspect every other year for wear.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      ok...we have that decided then.
      What about the fuel pump pushrod? Surely not everyone is injected.
      CHICAGO SUBURBS
      I've used Comp's roller tipped pushrod a bunch of times and they all still look as new after many miles. They have them for small block Chevys, I don't know what else.
      Frank B. 1968 Camaro 355 Procharged 6 speed. 1983 V8 S10. 1984 Monte Carlo Magnusen Charged iron 6.0. Plus a few other junkers!
      Southern Indiana
      ok as for me I installed a Roller in my big block and put about 90k on the Crane/Comp(not sure which) bronze, lived longer than the riveted bar lifters.
      On my LT4 HOT roller I put about 120k on a Comp bronze, found it worn replaced with cheap o lasted about 20k, the bronze comp push rod is same one I bought back in 94-95 for the bbc, probably 500k plus with no wear.
      Now LT HOT cam has melonized now, but since the compsite came out its a no brainer.
