Results 1 to 13 of 13
Thread: new guy from Los Angeles Ca.
- Jan 2009
- Van Nuys, CA
- 198
THis is my current project. Almost done with it.
Its a 1970 1/2 RS/SS Camaro with a GM crate motor a tremec TKO 600. I have tubular upper and lower global west control arms with a hotchkis suspension, front and rear. I have hotchkis front sway bar, stock rear. Bolt in subframe connector then welded in. Bilstien shocks front and Koni rear shocks. Wilwood 14 inch rotors front with 6 piston calipers, 12.75 rotors rear with 4 piston calipers. I have a quick ratio steering box. I have Bonspeed extreme 5 rims 18 inch front and 20 inch rear. Currently running Toyo Proxes. I put an aluminum Radiator with twin electric fans. I installed a 2 1/2 inch steel cowl hood running a 4 inch K&N air filter and the filter lid as well.
Mike
