Results 1 to 14 of 14
Thread: control arm suggestions
12-20-2008 #1
- Dec 2007
- michigan
- 370
I need some help. I am going to be buying a set of control arms for my 68 camaro. I'm probably going to go with tubular, but am not sure what brand to get. DSE, Global West, Hiedts? Im assuming the cheap deals you see on Ebay I should stay away from. The previous owner hit something and both of my lowers have curled lips on them, (stock ones) So I need to replace them anyway.
My car will be more or less a daily driver, more so a weekend car. I am not planning on racing it. I am keep the rear suspension stock with the exception of a rear sway bar added. I want the car to handle well, but also want it to be safe. I plan to run stock springs as well, meaning Im not planning on running coilover shocks. I've heard horror stories of aftermarkey arms breaking. Since I am not going to be racing or competing on any level, would I be better off just keeping the stock control arms?
Although, I would like to lower the car just a bit, maybe an inch or two. I plan on running 17's front and back as well.
thanks,
2005 CBR 1000RR..."mostly stock".
1968 camaro... "in the works".
12-20-2008 #2This is what I have:
Global West upper and lower control arms
QA double adjustable coilovers
AFX Tall spindle (3/4" drop)
Lee 670 Steering box.
Hotchkis hollow 1-1/16" front sway bar.
The tubular are a lot stronger than the stock stamped steel arms. I know you are not planning on running the coil overs, but being able to dial in your ride height is very nice, rather than messing with springs (cutting/spacers or pulling the springs to install different ones).
I think the DSE, Global West, Speedtech and SPC adjustable arms are all nice products. If it is in your budget I would look into the AFX spindle which is pretty much the largest gain in handling even over the control arms (which don't really add much to handling). If the spindle isn't then I would look into Guildstrand Mod or tall upper ball joint, which do add a lot to handling.
17" wheels and modern tires will also make a big difference.
Check out David Pozzi's site for the G-Mod:
http://www.pozziracing.com/first_gen...0upper%20mount
Lot of good information on his site.
Keeping the stock arms, doing a G-Mod or tall UBJ will give you a lot of bang for the buck. Whatever you do stay away from the drop spindles. You might also want to look into upgrading your steering box which also makes a huge difference in handling.
I'm sure someone else with more knowledge will chime in as well, but the above is what I learned when I was putting together my suspension package.
I would give Marcus at SC&C or Tyler at ATS or Frank at Prodigy Customs a call and discuss suspension options for your application they are all very helpful and really knowledgeable on how to setup our cars to handle.
SC&C
http://www.scandc.com/
ATS
http://www.t56kit.com/
Prodigy
http://www.prodigycustoms.com/
Good luck!
12-20-2008 #3Im am using GLobal West as well with Hotchkis Springs, Swaybars and Bilstein Shocks..
12-20-2008 #4
Banned
- Aug 2003
- Orlando, FL
- 8,745
We sell multiple brands of control arms. I think the best bang for the buck is Speedtech. We can put them on your doorstep for $1050
http://www.speedtech-performance.com...prod/prd47.htm
http://www.speedtech-performance.com...prod/prd44.htm
12-20-2008 #5
- Dec 2007
- michigan
- 370
thanks for the responses. that gives me some piece of mind. I was looking at global west as one of the possibilities.
From your response 69RS, I will more than likely go with the coil overs. For some reason, I didnt put it together about the ride height. I didnt see a huge benifit in a street car, but that swayed me.. Thanks,2005 CBR 1000RR..."mostly stock".
12-21-2008 #6The bottom arms are just along for the ride. It you are not going with coilovers in the future that would require the options available with lower arms just buy and install a good set of upper arms and call it good.
Save the money you would have spent on lower arms for another purchase that will give the car additional benefits in the future!
12-21-2008 #7stock lowers with delalum bushings and SPC uppers...
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
wir müssen Leben bis wir Sterben...
12-21-2008 #8
