    Results 1 to 10 of 10
      new york city
      trimmed taurus fan depth?
      I am about to purchase a taurus fan setup, but I need to know what depth they can be trimmed to. I have a big block with a long water pump in a 69 camaro and want to be absolutely positive I have enough clearance before ordering.
      Thanks for the help.
      Jun 2005
      Lynnwood Wa.
      It is 6" deep, No need to trim it for depth. Just trim off the stock mounting ears.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      new york city
      I only have about 4 inches of clearance between the radiator and water pump, that's the reason I am asking.I have a 11 inch dual set up right now , but the radiator core is not wide enough. the fan hangs over the side tank.
      Finding a good fan that fits is a real PITA.
      Jun 2005
      Lynnwood Wa.
      There is only 1 inch between the fan blade and the untrimed housing. So there is only 1/2" to 3/4" to trim. Can You use a short water pump?
      Oliver Shultz
      new york city
      I already have a serpentine setup mounted that uses a long water pump. I really cant afford to change the whole accessory drive just to get a fan to fit.
      Derale has a 17 inch low profile fan that flows 2500 cfm but I would really like 3500 cfm
      Henderson,NV
      I have dual 11" spals that are staggered and they fit the standard size core on a camaro. Northern radiator has them. Maybe to thick...my car is not here right now.
      Todd
      Jun 2008
      Jst trimmed one down the other day to fit a 5 in down pipe. :( I got it under 4in...plus it's the tall at the fan motor. So you could mover it around to get away from the water pump. Hope it helps.
      new york city
      Quote Originally Posted by Boosted67 View Post
      under 4 inches, that's what I was hoping to hear.
      Thank you
      new york city
      Do you happen to have any pictures of it after the trimming? How did you trim it? hacksaw, hot knife?
      Thanks for the info
      Jun 2008
      See if I can find at pic for ya. I trimmed with an airsaw, then air sander to level and flatten. Clipped about the least amount off, and it actually is a smigden too much. The fan barely touches. But it always does. but we put plastic lace around the cut edge to hide any imperfections, and cushion it to the rad. And it it gives it juuuust enough to clear.
