      Connecticut
      Jeep wrangler problem
      Hey guys my mom has an 04 Wrangler and the heater switch only works on high. she gets nothing on low or medium fan. could it be the switch itself or maybe a fuse? let me know what you guys think thanks
      Paul Krol
      1968 Camaro
      Jan 2009
      Most likely the blower motor resistor needs replacing. The resistor usually has three wires coming off it two of the wires will be different resistances for the low and medium switch setting and the third will be a direct path for the motor to ground. Thats why the high setting is still working, it doesnt rely on the resistor to complete the circuit.
      Hope that helps.
      USA
      Yep , sounds like the resistor.
      Jeff Tate
      U.S.A.
      Connecticut
      thanks guys i will start with that then. I really appreciate it.
      Paul Krol
      1968 Camaro
      Connecticut
      cool guys, do you know where i would find the resistor? is it behind the dash? or a under the hood thing? thanks
      Paul Krol
      1968 Camaro
      Jan 2009
      Havent done one on a wrangler but its usually an under the dash thing. Itll be on the passenger side and should be mounted onto the blower motor housing with a couple screws. Might have to remove the glove box to access it.
      Jan 2009
      http://www.answerbag.com/q_view/527529
      Found this. Answer two has a very good description and answer three has a diagram out of a service manual.
      Hope you get it fixed.
      Dave
      Connecticut
      that is great thank you so much
      Paul Krol
      1968 Camaro
