Results 1 to 14 of 14
Thread: Motor Options
03-03-2005 #1
- Oct 2002
- Houston,TX
- 630
Motor Options
I am going to build a motor for a pro-touring car.
I want to use the standard SBC not a LSanything.
This motor will most likely be EFI www.electromotive-inc.com
Steel block / Aluminum heads
The goal is durability, reliability, no custom parts, and the ability to be rebuilt in the future, and must run all day on pump gas.
I think that a good number to shoot for is 600hp, what I mean is that if it cost $200 more for 2hp then I will stop there. I kinda want the most bang for the buck. But I am willing to spend about 8K or so, on the motor.
In a different post ProdigyCustoms said that he would not build a 383 and would build a “406 to 434, (costing about the same to build around $8000 or so and ProCharge it (D-1SC around $2500 or so)” Does anyone know how exactly he plans on doing this? What block would you use? I think 406 would be plenty but if you went up to 434 is that bore and stoke or just a bigger bore? Prodigy if you would comment I would be greatly appetitive. I would just like to know a little more of the details.James J.
03-04-2005 #2
- Oct 2002
- Houston,TX
- 630
I forgot to mention that this motor will be used 95% of the time on the street. With some track time and maybe a few trips to the strip but I am not much of a drag racing fan so it will be for fun only.
And I am looking for something that will be able to be shifted no sooner then 6500, not that a hard thing to do.James J.
03-04-2005 #3
- Sep 2004
- VA
- 281
Well hes not wrong, I was going to suggest a 400 myself. Good motor. I'm sure he was thinking since you have to get a crank and all the goodies to go in it you might as well build a 434. I dunno if i'd supercharge it b/c I tend to think n/a motors make plenty of power for the street. Depends on what you would like to run at the track whether i'd supercharge it or not. I'm not sure you'd be at 600hp, but you should be happy with it.
"Does anyone know how exactly he plans on doing this? What block would you use? I think 406 would be plenty but if you went up to 434 is that bore and stoke or just a bigger bore? Prodigy if you would comment I would be greatly appetitive. I would just like to know a little more of the details."
Does anyone know how he's going to build it for the same price? I explained it above, basically you have to buy everything anyway, thats how he's figuring the same price. 434 is more stroke. Basically a +.030 bore with a 4.00" stroke. I tend to only suggest the 406 though. Less work (for the builder) well usually, and it seems to make plenty of power for doing whatever you wanna do on the street. You can prolly go with whatever he suggest, I doubt he'd steer ya wrong
03-05-2005 #4
Banned
- Aug 2003
- Orlando, FL
- 8,745
It is actually going to be cake to make only 600 HP. As my friend Ricoch stated, even N/A, just a 406 would make 600 HP. However, making 600 HP with a N/A motor 400 to 434 inches in a small block, with the head limitations of a small block, is going to make for a rumpty motor. I happen to run a N/A small block 404 pump gas 600 HP motor in a street racer. We cruise it a lot, but I am willing to put up with the fact it does not clear out until 4000 RPMs, if fact in this car I love it.
But for a cruiser, a car that is going to have some miles put on it, boost is best! Using a blower by a number of manufactures, or turbo (s), will make 600 by accident. We have a ProCharger on order right now for a 355 that we expect 650 out of with 10 LBS boost. It is a nice 355, but no real rocket science in it. Basically some decent heads and a nice combination of parts that work. i would guess the cost of the 355 was $6000 or so, maybe a tiny bit more? And p series blower is under $2500.
As far as my fast math $8000 + a blower, $11,000 budget. That is a real round number for a guy asking a very round question. Basically there are many crate engines available and just specking the right cam and blowing a few lbs of boost will easily exceed your goal of just 600 HP. With 400+ inches and the good parts these motor come with, you will have no problem making what you want for HP.
As far a specking out exact parts. When you are ready, ready, I will be happy to help you select parts. I can even provide parts if you so desire, or you can buy elsewhere.
http://www.primediapowerpages.com/cg...03931&2D104451
There is a 415" motor in the catalog complete carb to pan for $7500 that makes 450 N/A. A slight cam change that should not be much more then a few dollars, and a ProCharger, and you are there.
If you are serious and ready to order, give me a call. We can call Bill Mitchell for you, spec out you order, set you up with the blower, and get it all sent to you.
03-05-2005 #5
