Thread: Help With Coil-over Spring Rates
03-03-2005 #1
- May 2003
- St. Charles, Mo
- 424
I知 getting ready to purchase my shocks and springs and I need to pick out my spring rates. Would any of you have a suggested wheel rate I should shoot for?
I am shooting for a curb weight of 3000lbs for the Nova with a 55% front bias. That痴 about 825lbs per front wheel and about 675lbs per rear wheel. I知 also going to be using the QA1 single adjustable shock DR8855B on all four corners.
For the front suspension geometry, the distance from the lower inner pivot to the coil over shock lower mount is 12.38 inches. The distance from the lower inner pivot to center of the wheel will be about 19 inches. The front shocks lean in at about a 15 degree angle.
The rear suspension is just a solid axle with a custom designed 4-link. The rear coil-overs are only angled in about 2 degrees.
I知 looking for a suggestion for both the front and rear spring rates. I will be driving the car quite a bit even on some longer road trips. I知 not sure if I値l be hitting many track events, the wife might have issues with that. Thanks for any advise you guys may have.
Thanks.
Dennis
03-03-2005 #2
Starting The Transformation
- Jan 2005
- 160
I'll take a wild stab at this. Let me qualify this by saying I have zero experience with your type of car and just took a stab at some calculations. I'm sure someone will get on here that knows what they're talking about on this particular car and then I can see how my numbers compare. I used some weight transfer formulas and some spring calc formulas that I have used in that past that have worked for my applications.
I'm going to say 725 for the front and somewhere around 225 or so for the rear although I don't know your motion ratio and I'm used to working with coils, not leaf springs. Also keep in mind that this would be without a sway bar so they might be a little high. Just for comparison I figured a front wheel rate of about 309 lbs. I'm interested in seeing how my dirt track numbers compare to asphalt stuff.
Like I said, don't order anything based on my guess but it will be interesting to see other opinions.
Wally
03-03-2005 #3309 lb wheel rate may be bit too stiff for a street car especially if it doesn't see a track. But I guess my guestimate would come out about the same if I figure it w/ no bar. I've done a '55 Chevy street car before - it did 0.94G on 200' circle on BFG KDs. 3500lb running weight with 51% on nose. Its wheel rates are 250 lb/in front and 216 lb/in rear, with bars on both ends.
I can't really estimate front spring rate w/o knowing motion ratio, but I'd also go with 225 lb/in-ish rear springs if there's no rear bar. Or 175-ish with a small bar.The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
03-03-2005 #4
- May 2003
- St. Charles, Mo
- 424
Spring rates
I guess I forgot to add that I have a 1.25 dia. x .095 wall front swaybar that is about 34.5" long with 11.5" long lever arms. It is a Speedway Engineering sway bar. As of right now, I don't have a rear swaybar but can add one if required.
I included the distance from the lower control arm pivot to the shock mount and to the center of the wheel, 12.38" and 19" respectively, in the above thread if anyone wanted to calculate the motion ratios. The distance from the pivot to the balljoint center is 14.88".
Thanks for the advice.
Dennis Linson
03-03-2005 #5
