Thread: Offset dowel question..
01-05-2009 #1
- Mar 2005
- 41
I purchased a set of offset dowels from a local speed shop for aligning my bellhousing for my new tko-600. They fit in the block without any need to press them in and spin with the help of a standard screwdriver. The kit provides a set screw and the expectation is to drill and tap the block and lock them down once the desired offset is acheived. Since I am doing this with the engine in the car, this is not an option. My question is what role do the dowels play other than alignment? am i risking anything by not locking them down? once alignment is achieved and the housing is torqued I should be good right? I planned on etching in the final position for reference in the future if I need to tear it down. What are your thoughts?
