Thread: Fuel system reccomendation
01-01-2009 #1
I have a 69 Camaro, stock fuel tank with stock sending unit. I have about 650 HP with 1050 holley and need a rec for how to run fuel lines. I was thinking if using inline tube products and cutting off the end to spice in the hoses from the tank to the electric pump and the other end at the regualtor to the dual feed carb set up. Looking for the gothchas and if this will work out ok. Car is mini tubbed with a 4 link..
Thanks for the help.
01-01-2009 #2Check this out by Aeromotive:
http://www.aeromotiveinc.com/d_syste...emdisplay=carb
Still working on plumbing my fuel system. I have a big block with about 600hp and I went with their SS Series, dual 1/2" stainless lines (aftermarket sumped tank thou). 100 micron filter before the pump, 10 micron after, regulator up front near the carb with the return line back to the tank.
Hope this helps.
