      Colorado
      LS1 fuel pressure range?
      Hello Everyone-
      I was curious if anyone knew the fuel pressure range for the LS1. I know that you need a minimum of 58lbs at the rail, but what is the spec for idle pressure and under load or high rpm.
      I am asking this because I have an 02 LS1 in my 79 malibu and used a walboro in tank pump with the 99 vette filter/reg and belive that the filter/reg was bad from the start. I am loading fuel extremely bad and my pressure at idle is around 100lbs at the rail. I have another filter on order but just wanted to get some opinions. I do not have my diagnostic port wired yet but I will sortly. Thanks
