    Results 1 to 17 of 17
      Snohomish, Washington
      Some Good Torque Wrenchs??
      Hey guys getting ready to start on my suspension and was wondering what some good torque wrenchs are. I was looking at some snap on ones.. this one in particular...
      http://buy1.snapon.com/catalog/item....re&dir=catalog
      Has anyone ever tried one of these?
      Any other ideas on some would be great! thanks
      Matt
      Cumberland, Maryland
      Yes they work quite well and are probably the most popular beyond craftsman. You probably can go wrong with any of the big suppliers though...Mac, Matco...
      Keller, Texas
      Watch ebay and pick one of these up instead.
      I watched awhile and found one used very little with box, paperwork, etc for $250. If you are working on anything late model the automatic torque angle measuring is the cat's meow.
      Greg
      1970 challenger convert-in process
      1970 barracuda-driver
      Jul 2007
      Los Angeles, CA
      I have used the Tech wrenches at school and I love them. If I could I would use nothing else but the Snapon tech wrenches they are very accurate and easy to use and to see you coming up on the torque spec. Wish I had sprung for them rather than the older school click type.
      hmm, thanks guys. Was wondering if the max ft lbs. that they go up to (250ftlbs) is enough for suspension. im new to all this and dont know.
      Matt
      Quote Originally Posted by gkring View Post
      what do you mean by the "automatic torque angle measuring"? im confused on the "angle measuring", whats the purpose of that? Sorry for the dumb questions just want to find as much as i can out befor i start bolting up suspension stuff!
      Matt
      Aug 2005
      Asheville, NC
      Torque and angle (tighten to a lower torque then turn an additional angle like 90deg) is way more accurate than just a torque, but chances are not much you are working on will have a torque & angle spec. I have heard the LSX rocker bolts are torque + angle.
      I like my snapon torque wrenches (but they are expensive) & have heard complaints about the click style craftsman wrenches breaking after about 2yrs & can't be returned.
      yes 250ftlbs will be more than enough for most suspension applications.
      when you start working on big trucks, school buses and such you then may run into problems. At that point though you'll probably invest in 3/4" and 1" drive tools.
      hmm thanks guys, and justforfun, thanks for clearing that up for me! going to keep an eye out on ebay for that torque wrench gkring posted.
      Matt
      MD
      I have a couple Snap On and love them. I wouldnt own another brand torque wrench.
      Southern Indiana
      Have the 3/8 Tech angle wrench, and hope to afford the 1/2 soon too but have changed jobs and had to pick up more tools, a lap top for work and such so money had to go elsewhere.
      Harriman, Tennessee
      Quote Originally Posted by Rallye455 View Post
      Why not? Many of the Snap On torque wrenches are made by Central Tools (NOT "Central Pneumatic!), with Snap On ratchet heads, and can usually be purchased at more reasonable prices.
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Feb 2006
      Idaho Falls, Id
      I have a beef with the torque angle function on digital torque wrenches. I was using a snap on unit to torque head bolts on a 5.4l Ford. The problem I had was that when the bolts were getting tight, they stopped turning really smoothly and would "jump" slightly as I tightened them more. Well the torque wrench didn't pick up those jumps and didn't count that part of the movement into the angle. So basically if I kept turning to the required angle they would've been over tight. Maybe I should've done something to prevent the bolts from doing that, maybe I should've lubed them differently, but that's the problem I've had with them.
      Traven
      Farmington Hills, MI
      Whats a torque wrench? What happened to Good n Tight????
      I use snap on wrench's exclusively. We have to have them calibrated every month as well. I have a set of Craftsman for home, and they actually cal better than the snap on wrench's. I'd use them at work, but the engineers have an issue with the less expensive tools.
      JEFF SHORTT
      -IDEAL STEEL
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by GBodyGMachine View Post
      I dunno one of the demos the Snap-on guys did was calibrate one of their torque wrenches against a Sears (and other brands). It was scary how far off Sears was compared to the Snap-On one that was within about 0.01%.
      Quote Originally Posted by 1969CamaroRS View Post
      Thats a demo, not after months of use in a shop correct?
      JEFF SHORTT
      -IDEAL STEEL
      Oct 2006
      Chicago
      I have a 3/8" TechWrench... 5 years old, calibration was still dead on. And it's been used quite a bit. I really like it.
      I also like the Snap-On Wrenches that use the torsion bar instead of the spring, or whatever it is... they have the side thumb knob rather than the rotating handle.
      Luke
      '63 Chevy II wagon - project
