      Oct 2007
      ridgefield ct
      95 caprice UCA length?
      this winter i'll be trying to swap the b-body rear i have into my g-body. i'm hoping to fing pre-built UCA's in the right length, but i can't find the actual length of the b-body arms. anybody know what it is?
      also, i know that the mounting angle of the arms is the same, but the upper "ears" on the rear axle are about 3in farther forward than on the g-body rear. is this going to cause handling issues (assuming i set the pinion angle correctly)? the car is going to see 90% street use and is lowered about 1-1.5in in the rear.
      thanks for the help
      Appleton WI
      95 Caprice UCA dimensions
      The dimensions from the center of the mounting holes is 11 3/16" with a total overall length of 14". I know that you can get adjustable uppers from Global West and BMR for the Caprice/Impala SS platform. If I'm not mistaken though, there were three lengths offered from the factory to counter a problem that GM had with holes stamped in the wrong place fo the lower arms. If I remember correctly, there was one 1/8" shorter and one 1/8" longer than the one pictured but all three had an overall total length of 14".
      Jim
      Oct 2007
      ridgefield ct
      thanks for the measurements. it looks like i'll have to "custom" fab some arms for mine.
