      new york city
      broken reluctor wheel
      So I was putting the vacuum advance canister back on my MSD distributor and I broke one of the teeth off the reluctor wheel. I have a new reluctor and I knocked the roll pin out of the cam gear. The gear won't come off.
      Am I doing this right?
      Rural Retreat,VA
      I think it must be pressed off...but be very careful and do not bust the gear.
      Central CA USA
      Sometimes the roll pin makes a burr on the shaft and makes gear removal harder but it shouldn't be too difficult to remove it.
      new york city
      Quote Originally Posted by David Pozzi View Post
      so it should come off by hand? It seems to be on there pretty tight.
      Central CA USA
      The one I changed a while back on an MSD distributor pulled off with hand pressure only. Yours might be different.
      David
      Keep in mind the reluctor wheel has to be put on exactly in the same position. You can buy the tool but it costs about $200. I am having one done at Boyds Machine in Norman OK. They heat the crank, then press the new wheel on - costs $25, you can buy the new wheel from GM. That is the only way to fly in my opinion.
      Quote Originally Posted by gggoad View Post
      He is talking about the pick-up reluctor on an MSD dist...
      Southern Indiana
      If your replacing it simply use a propane torch to warm it up , careful of any plastic in the advance mechanism best to disassemble it first, then it should come off with minor difficulty, then slide a new one on, if I remember correctly its the same one as a Ford V8 available from local parts houses.
      Good Luck
