    Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 61 to 80 of 87
    Thread: '77 Impala
    1. #61
      Charlotte
      Damn... just noticed this was on the Power Tour... where you a long hauler? There where so many cars in Madison that I didn't see it there or the other stops.
      2014 Chevy SS LS3 / 4 Door
    2. #62
      Dec 2008
      Wisconsin
      Well I have finally driven the Caprice with the 4-speed
      Everything is finished except for an alignment.
      BUT
      the power brakes have no power assist. I replaced the New power steering pump and the NEW hydraboost unit still no power to the brakes. The power steering is ok but there must ait trapped in the hydraboost unit
      frustrating
    3. #63
      Dec 2008
      Wisconsin
      The good news is the power brakes finally work. The air in the system finally worked its way out. This took between 60 and 80 miles.
      Here are some shots of my Caprice. This has a mild 350 and a Super T-10. It can't get out of its way because it has 2.41 rear gears..... for now. It does well for mileage on the highway.
      The clutch set up and the Hydraboost are the same as in the Impala.
      This is my winter lowrider.
    4. #64
      Oct 2007
      McHenry, Il.
      If you run across a good condition 79-80's ish 2dr, let me know. I REALLY miss my 80 impala.
      Your cars look sweet, the 4spd blows me away. I wanna do one with a stock LS drivetrain and a later model interior. I wasn't a big fan of that stock dash.
    5. #65
      Dec 2008
      Wisconsin
      Happy to report the Caprice is doing well as a winter car.
      I cut 1/2 coil out of the stock rear spring and put hoses back in
      It helps with the 350 lbs in the trunk.
      So far Dec has been an exciting month. 18-20 inches og snow last week and then temps in the -0s. I'm glad to say the aftermarket hot rod parts seem to be holding up well. .in this car I used the latest version of Howe racings stock clutch release bearing. The T-5 version is what fit behind m my stock replacement clutch and in front of my Super T10.
      This latest version is better than the previous ones offered in that it can not be over strocked. Also the o-rings are at least
      twice as thick as earlier offerings.
      For about a week before the snow/salt hit here in So Wis I was able to drive the Caprice and the Impala back to back
      Kind of like having sisters.... similar yet so different.
      I guess the Caprice is like the slower slightly retarded version
      of the Impala. Still its cool havin a beater with a Hurst shifted 4-speed and headers/flowmasters. Almost makes winter ok. And whiping dounuts is too cool.
      Future plans for the Caprice involce 3.08 rear gears and a posi unit.
      As for the Impala
      Winter updates will probably include a Hurst shifter for the T-56 and an update for the rear control arms.
      Right now I' m looking at the Global West lowers. They dont offer an upper yet but they have uppers for the '73-77 A bodies which may work
      will need to check into that.
    6. #66
      Dec 2008
      Wisconsin
      Ah proof reading:
      what I ment is I put those back in refering to the cut stock rear springs. The lowering spring couldn't deal with the winter weight over the rear end. Also this one has a reman jet Performance Q jet and a block heater. It help when the morning temps are 5-10 below 0
      Enough about the winter car I'll post more on the Real one as I make changes this winter
    7. #67
      May 2008
      Merewether
      Country Flag: Australia
      Look forward to more updates!
    8. #68
      Dec 2008
      Wisconsin
      Time to play the hand me down game.
      The winter car needs a radiator
      so
      I'm going to put the 3-row from my Impala
      in the blue car and get an alum. for the Impala
      nothing new but that
    9. #69
      May 2006
      grafton ontario
      Sharp car matt , most suspension parts that you are looking for are the same as the 73/77 A-bodies . GW has them
      mike.
      Home of the red & white money pit.
    10. #70
      Dec 2008
      Wisconsin
      I picked up a first gen Edlebrock Pro Flo system for the Impala. It was on my brother's '72 Nova befor he installed the 6.0 LQ4. I think it has 3000 miles on it. We installed the intake last Friday and my brother will post pics here soon. I'm waiting for the ZZ4 chip from Edlebrock and still need to set up the new fuel delivery system. This should be lots of fun.
    11. #71
      Jul 2007
      Wisconsin
      Here are some pictures of the Pro-Flow intake as we removed the old and sealed it up with the new. The system is really straight forward. It only takes 2 wires from the fuse box to make this happen. A constant power and a keyed ignition wire. If I hadn't had the LQ4 for my Nova I would still have this on a small block in there.
      Before:
      After:
    12. #72
      Jun 2008
      green bay wisconsin
      Where is Wisconsin are you from? I"m in Green Bay. Nice ride, all i have is a 70 Nova 4 door. Brandon
    13. #73
      Dec 2008
      Wisconsin
      Brandon,
      I'm in the Madison area
      good luck with your nova.
      Besides the B-bodys I've got a '63 sSS Nova
    14. #74
      Dec 2008
      Wisconsin
      The Pro-flo system is great. Easy to get the car started
      and setting the base timing and idle. I drove it a little and
      the car is very responsive. It looks like I have a small oil
      leak at the back of the intake. I'm not sure why there would
      be oil at the back ( where the head and intake meet ) but when the car warms up and sees some rpm there is a small oil trail that runs down to the bellhousing. Guess I'll pull the intake and reseal it.
    15. #75
      Aug 2006
      Gum spring,Va.
      just a note, Next time you reseal the intake,Not sure if you have done it already, but pick up a can of Right Stuff sealant from permatex It looks like a squeeze cheese can Works 900X's better than regular RTV.
      Also you might want to try some MOOG CC627 rear springs, They are a cargo coil for a g body. and alot of impala and 94-96 caprice guys use em to lower the rear of the whale caprices and still be able to haul stuff in the trunk.
      Compairo from My 94 I used em on
      Before 1 coil cut off the front 9C1 coils stock rear springs
      After the 627's
      "Rockford, this is Tony. Now, your car's
      ready. Couldn't reach you, so I went ahead and put in the new pistons. The
      tab's $527.54. And this time we're talking cash. "
    16. #76
      Dec 2008
      Wisconsin
      I am running the SPC adjustable upper A-arms with the greaseable
      steel-on-steel "race" style bushings. At some point they quite taking grease and would only push the grease gun off the zerk. When i took them apart 3 of the 4 wouldn't push grease through the small hole in the cross shaft even with the bushing off. The shaft and the bushing are to worn to use and I am going to replace them. I am trying to decide if I should replace them with the same or switch the rubber bushed "street" style. SPC says dirt can clog up the small hole and prevent proper greasing. They recomend disassembley and cleaning
      often. Anyone have a similar experiance with these on the street and
      will I be dissapointed if I change to the "street" style.
    17. #77
      Jan 2010
      Elk River, MN
      Man, sorry to hear that about the SPC arms, I don't want to be ripping my A-Arms off all the time for cleaning :(
      -matt
    18. #78
      Quote Originally Posted by Impala Matt View Post
      But they sell these for circle track use! Are circle track guys disassembling and cleaning after every race? I figured since they are used for that purpose, the only reason for calling them track-use was because you did have to occasionally grease them (which a lot of people would neglect to do) and maybe increased wear rate since they are steel on steel.
    19. #79
      Jan 2010
      Elk River, MN
      We run similar ones on our Touring late model and have never had them apart, some of the greasable racing arms simply can't be disassembled. That's why this bugs me, I'm apprehensive about ordering the greasable arms if they got that bad so fast. I hope they're at least somewhat good at keeping dirt out, but this has me concerned.
      -matt
    20. #80
      Aug 2006
      Gum spring,Va.
      Just to bring this to the top I have 2 77's now..lol
      The 94 frame and LT1 swap for the blue one
      and the new Stocker 77 ..
      Interior is perfect..
      got a carbed LT1 I'm building for this one..
