    Results 1 to 20 of 31
      Garden Grove Calif
      Autocross advice wanted ...
      I'm going to try my first ever autocross soon. I have a 69 Camaro, the back is Quadra linked, 315/17 tires. The front, Speed Tech A arms relocated with Guldstrand mod , QA1 coil over conversion, upgraded power steering system, 245/17 front tires. Subframe connectors. Like to hear from any and all that have advice on setup, driving technique. Love to hear from David and/or Mary. Carl C Tony H or Mark S. Thanks for your input.............Mike
      USA
      What kind of tires do you have ?
      What is the treadwear rating ?
      The available grip makes a lot of difference.
      Jeff Tate
      U.S.A.
      May 2006
      Orangeville, Ontario Canada
      Get this:
      http://www.soloracer.com/solosecrets.html
      Then get your hands on some chalk, an air pump and a tire pressure gauge. A friend with a good video camera will help as well.
      Take your time on your first few laps; and I mean TAKE YOUR TIME! You won't be able to read and navigate the cones as fast as you would the tarmac on a road course.
      Don't try and impress everyone with the cubic dollars in your parts... impress them with your ability to ask questions and request ride alongs (both in their cars and in yours).
      1987 Monte Carlo Super Slow - Super Worn Out 355, Carb, Giggle Juice, 3" Duals, 200-4R & 4.56s
      1987 Turtle Buick - T63e, 83s, FMIC, MPE DP, PowerLogger, MAFT Pro, 4" Single, ProPain & 3.08s
      2002 Crapmaro B4C - LS1, A4, SLP Lid, DiabloSport, Cutout & 3.23s
      2007 TrailBlazer Super Slug - LS2, A4, AWD, Tune, CAI, Exhaust & 4.11s
      If you didn't build it, it's not yours.
      Central California
      Quote Originally Posted by motorheadmike View Post
      Get this:
      Great advice here ...
      As you've never ever autocrossed before, tell the folks at registration as they'll partner you up with someone experienced. The So. Cal. area is rich with excellent autocrossers and Solo 2 National Champions.
      As for your car, there's not much to change from what you mentioned. What rear tires are being used and most important, what brand and model. You definitely want to go with a treadwear rating of 100 or less (preferably less) for autocrossing. If the tires are handling dual duty (street and autocross), then think closer to that 100 treadwear. Both Nitto and Toyo make tires that will fit your wheels yet offer some fun times. Raise the tire pressures to at least 35 psi, preferably 40, for start pressures. Use the chalk or white shoe polish to check for sidewall flex and roll.
      Try for about 1-1.5 negative camber, as much positive caster as you can get, and 1/16-1/32"" toe-in. If you're worried about excessive tire wear on the street then err on the conservative side for camber. Toe is what really kills tires so be very accurate there.
      There's also an autocross school coming to the El Toro base that's very good. I hope to come down there and take the Level 1 (everyone starts there regardless if they're new or been to Nationals a hundred times). Evolution Driving Schools hosts it.
      Get to the event early. Your car will probably be placed in either E Street Prepared or C Prepared as it's definitely not stock (and a stock '69 Camaro would handle awful ...). Most autocross events go "hot" around 9am so get there at 7:30. You'll need to register, have your car teched, and then walk the course. Walk the course at least three times and do this with someone experienced. Most events have a "novice coursewalk" that's conducted by someone good so take advantage of this. Getting there early also usually gives you a good pit space. Make sure to clean out the car before you leave for the event as you don't want anything loose running around your feet while on course. You might also have a specific run group. And you'll also have to work the event. If you work before you run, work the course as you'll get to see several corners from an entirely different vantage point.
      When you're walking the course, walk as if you're in the driver's seat, i.e. give that four+ feet room on the right side of the cones. Look ahead and think about what your car is doing NOW. Plan where you want to brake, transition back to the throttle, and then exit that corner onto the next. Think about the course as sections, not individual corners. A mistake takes time as you have to reposition the car and get it back into compliance, reacquire the track, and continue from there. And the fastest autocrossers will look very slow as they're smooth. Drivers that are sliding and locking up wheels will look impressive to a newbie but will be slow.
      And don't abuse the equipment. The sliding/locking wheels isn't good use of the car and there's no reason for it. Listen to the car as they communicate what's happening to a driver very well. Think about being proactive instead of reactive. If you want the car to rotate, then set it up and drive it accordingly.
      Your first run should be your slowest (you'll probably get three, possibly four runs) as that's the one you use to learn the course, where you go, how the corners are linked into sections, etc. Work up to speed from there and don't worry about hitting cones. If you're going through a section well, don't try to go faster but work on improving the other parts that you didn't do as well.
      And look up ... can't stress this enough.
      Know this is long and you'll love this sport. And keep the questions coming ...
      Cheers and enjoy,
      Mary Pozzi
      "STICK, you B*TCH!!!!!!"
      Sep 2002
      San Jose, CA
      You running an Automatic Trans?
      Just call me Brett
      Little Rock, Arkansas
      Only done it once but I learned a valuable lesson. Slower is often faster. Don't over drive the car.
      westchester county new york
      Smoooooooooooooooooooooooooooooooooooooooooooooooo oooooooooth.
      Ft Polk, LA
      Gotta agree with everyone here. Slow is smooth; smooth is fast.
      Weldon Malbrough
      SSG, USA
      4th BCT, 10th MTN DIV (LI)
      It is great to be in the U.S.
      Garden Grove Calif
      Thanks everyone I'm trying to absorb all this info. More about the car. It is a street car. Tires are Dunlop 8000 series rear and 8080 series front. I dont know any of the traction specs, if you do let me know if I made a good choice or not. The autocross I'm going to do is at the Goodguys in Costa Mesa. Also how do I find out about the event at El Toro Mary? When I had the car aligned I used some pretty agressive specs I got fron Carl C. As I remember I went fairly agressive with camber and I think its got 1/16 toe out as I remember. The car is automatic trans now. Soon to have a Tremec. I think for a rookie, auto will be good for 1st time. I looked at the Dunlop site it looks like the tires have treadwear of 200. Too hard huh.
      Central California
      Quote Originally Posted by hotrod69camaro View Post
      No problem and the cool thing about autocrossing is you can take it in steps. The Goodguys autocross is held by Ride Tech (air ride Technologies) and the course is pretty small as they don't have a lot of space to work with. From past years, the times have been under 20 seconds but the good thing is you get as many runs as time permits. I haven't run their autocrosses but hear very good things about them and that they're fun. Also a great place to socialize with other gearheads like us.
      I hope to be down at the Costa Mesa Goodguys next year and look me up.
      Toe-out will help with corner entry but will also promote some tire wear. Err on the side of caution and zero the toe if you get the steering aligned as your tires will love you. For a course of this size with tight turns at low speeds, turn-in isn't as critical. Increase tire pressures to about 35 psi. And the good thing is ART specifies a treadwear limit so you're not competing against R-comp shod cars. Your 200's should be fine.
      An automatic trans is not a liability and can be an advantage as you can left foot brake. I've never gotten the hang of this but most of the fast guys swear by it. For me, I swear AT it ... but then that's why I'm going to the school I mentioned earlier. I'll send you a PM once I get more information and the date I'll be there.
      Cheers,
      Mary Pozzi
      Newbury Park, CA
      Mary is the Queen Bee of AC and HPDE's. I've learned a ton from her and David.
      It's all about the line. Slow down, go faster. Listen, ask questions, watch others.
      I would not worry about the front alignment too much. With that much rear tire you will likely need as much front bite as possible.
      One of the tools that David gave me that I watch again and again is is the video "How to Autocross." I learn something every time I watch it, and then try to apply, even if it's just driving on the street.
      Sarasota, Fl
      I'll offer a bit of advice no one else bothered with... probably because they've been doing it so long that they've forgotten:
      Don't worry about looking like an idiot, because you will. Everyone does their first time out, so go ahead and get it out of the way, get rid of the embarrassment (and you will feel embarrassed), look foolish, and then take a deep breath and remember you're there to have fun. Only after you've gone through that will any of the advice people posted above start to have real value.
      Other than that, there's plenty of good advice here to keep you occupied for your next 10 auto-x sessions.
      Good luck and have fun!
      Central California
      And we have a LOT of grins and giggles, too.
      http://www.lateral-g.net/forums/showthread.php4?t=18114
      Cheers,
      Mary Pozzi
      Sep 2002
      San Jose, CA
      No helmet on the auto-x video... for shame :D
      I've been auto-xing for 10 years now and make an ass out of myself at least once every event. If you don't do something stupid every once in awhile you aren't pushing hard enough
      Just call me Brett
      Fontana, CA
      This is one of the first thing I noticed as well.
      Also, remember to walk the course. Get the idea of the course layout first off.
      Nick R.
      Mantorville, MN
      In slow, Out fast.
      In fast, Out backwards.
      Derek Kiefer,
      Mantorville, MN
      First Gen Auto-X
      Mike,
      Hope you aleady did your first event. Great advice here all around. I started Autocrossing my '68 Camaro late in 2007 so am still on the steep part of the learning curve. I chronical a lot of what i learned and a lot of my build in my blog (listed below in my sig). Also chronical all my mistakes, so hopefully others can avoid them. Folks here have been great! The most important thing though is to be smooth. Mary said it best, the fastest drivers will look slow because they are so smooth. Try non-violent application of the throttle and brakes--it's a little non-intuitive but transistion from throttle to brakes quickly but then apply them steadily rather than mashing into them. This upsets the car the least and allows for smooth driving, which is fast driving. To get tire pressure correct, buy a small hand-held IR thermometer and shoot the tires right after a run. If they are hot in the middle relative to outsides, you are running too much pressure. There are other rules of thumb for tire pressure and alignment you can glean from tire temps, so this is a good tool.
      Have fun!
      Paul
      Central California
      Hi Paul,
      Great advice as well and turns out we have a mutual friend ... Ann Hollis. She says it's a very small world ...
      Cheers,
      Mary Pozzi
      USA
      I noticed that if I go into a curve easy and power out of the curve , I run faster times.
      In other words , don't brake too late.
      Don't run wide open all the way deep into a curve and then stomp the brakes and turn the wheel.
      I have a bad habit of doing this and all it does is slide the front tires sideways.
      I found that if I go in soft and come out hard , I run better times.
      These front engine musclecars are nose heavy anyway , and its easy to induce undertsteer by overpowering the front tires and breaking them loose.
      Jeff Tate
      U.S.A.
      Long Beach, Ca
      So glad you asked this question Hotrod, as this event will be my fist as well. Only my car isn't nearly as hooked up as your car!
      The chalk is an awesome idea, going to run over to the vacant parking lot later!
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
