    Results 21 to 33 of 33
      Jul 2008
      Maple Ridge, BC,Canada
      700R4 Build, tough enough?
      Here is a list of parts tranny guys are quoting to use for a 700R4 build to stand behind my 70 Nova -
      Current car specs-
      Engine is a .040 over balanced 400 small block
      Block is decked and drilled for steam holes
      Scat 9000 crank
      Scat forged 4130 5.700" Rods, ARP 8740 Bolts
      Mahle pistons 10:44 compression
      Competition valve train
      Crane gold full roller rockers
      Competition Cam 284xe.
      AFR 210 Fully CNC Heads.
      Hogged out RPM Air Gap Manifold
      Custom 950 Pro Series Carb
      3:77 gears
      Dyno'd at 488 HP 504 TQ
      @ motor
      I have a stock console shifter
      What do you tranny pros think? Good parts, good build for the following?:
      All frictions (except 3/4 clutch pack) will be Red Eagle coupled with Kolene Steels.
      -3/4 Clutch Pack will be High Energy Frictions. (The Red Eagle/Kolene Clutch Pack consists of Frictions & Steels that are too thin which overheats & burns up). -Harden Input Shaft with Reinforcement Sleeve (will accept up to 600 ft lbs of Torque).
      -Welded SunGear Shell to SunGear (OEM is weakest part of the 700R4)
      -High Energy 2/4 Band.
      -.500 Boost Valve
      -.279 Reverse Boost Valve
      -Transmission will be set up so that you will NOT require any wiring to operate the Torque Converter Lock-up.
      -1/2 and 3/4 Corvette Servo assembly. This provides the greatest Clamping available for the Band in both 2nd and 4th Gear.
      -B&M Street & Strip Shift Kit which will allow you to shift both Manually and
      Automatically.
      -All the Brackets, Clamps, Cables, and Linkage necessary to operate your Trans properly and fit in your car Professionally.
      Converter suggestions??
      Thank you.
      70 Nova - 406 sb -488 HP/504 TQ-3:73's
      http://s66.photobucket.com/albums/h266/steelratnova/
