    Results 1 to 10 of 10
    Thread: Get more grip
      Apr 2008
      Country Flag: Sweden
      Get more grip
      Hi guys. Is this worth doing or not? Looks pretty simple but there's maybe downsides?
      http://www.popularhotrodding.com/tec...ech/index.html
      La La Land, CA
      It's called the Guldstrand Mod. Yes, it works. I can't think of any performance downside, but if you want an unmolested frame, you should look to tall spindles or ball joints.
      Tyler
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by titojones View Post
      it's called the guldstrand mod. Yes, it works. I can't think of any performance downside, but if you want an unmolested frame, you should look to tall spindles or ball joints.
      Tyler
      xx2
      David Sloan
      Jul 2003
      Anaheim Hills, CA
      The guy that wrote that is a bufoon.. lol
      But seriously, it's a great mod and the only downside is a couple of holes in your frame. Also, I'm pretty sure the quite a few aftermarket control arms even work with this mod.
      If you call Gulstrands they will send the template for a couple of bucks.
      1968 Track Rat Camaro:
      Oct 2007
      Union Mo
      Is there any info on which way will produce the best camber curve?
      Apr 2008
      Quote Originally Posted by Steve1968LS2 View Post
      Thanks, I have the template but consider instead to use tall ball joints. Will they give the same result? It sounds more comfortable and the car can be restored in the future. Where can I find thoose ball joints? Will the fit on the stock control arms?
      Mountain Springs, Texas
      Quote Originally Posted by BlueBull View Post
      Mark at SC&C is the one to talk to about tall ball joints. He is a sponsor here:
      http://www.scandc.com/
      Don
      Jul 2007
      Calgary, Canada
      http://www.t56kit.com/
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
      Quote Originally Posted by TitoJones View Post
      Tyler
      What if you've done this mod, then want to go with the tall spindles later. Are the two compatible?
      La La Land, CA
      If you left the factory holes in place and did not cut them off, yes. You would put the control arm back to stock and then add the tall spindle.
      Tyler
