      Feb 2007
      Loganville GA
      figuring BS when using drop spindles
      I have an 86 Buick GN, I currectly sit dropped 1" and 16x8.5 wheels 245/50s. I have a set of 2" BT drop spindles I am putting on, but I can't w/ my current wheels, because it'd sit the tire on the fender lip, and not allow it to roll. I want to run an 8.5" wide wheel,(19" or 20") but dont know what to figure to add to the BS to help clear when my wheel travel arc is essentially moved up 2". Does anyone know what BS would clear or what to figure the change at to clear.
      I know many people hate drop spindles, I know the whole argument. I understand, this is about the budget and my intentions for the car.
      any help appreciated
      Greg
      86 Buick GN, 20"s, 3" drop, TE44 and more
      05 Ram 1500QC dropped 6"+
      06 Stratos 201ProXL Yammie 225..not stock
      Sep 2007
      Edmonton, Alberta
      Can't tell you how much b.s. to run. But I can tell you that the b.t. spindles will move the wheel out 0.5" on each side. So if you figure out what b.s. you had before, a little math to add that increased offset to your choice of wheel will give you an answer.
      Hope that helps a little.
      Ryer
      Feb 2007
      Loganville GA
      Quote Originally Posted by bbcc View Post
      Ryer
      If .5" is the actual # , thats exactly what I need. That should be normal "recommended BS" plus .5" then.
      Greg
      Sep 2007
      Edmonton, Alberta
      Yup, as long as it is the b.t. #2100, it is 0.5" (as a general rule of course).
