    Results 1 to 13 of 13
      Dallas TX
      Pitman arm stuck (HEEEEELP)
      I am running out of things to try. I have a new Lee box but it has the wront pitman arm installed for my car. The arm went on no problem. It was tightend with an impact. I went to switch it out the other day and could not get it off with a 3 jaw puller and an impact. Plan 2 cut a "U" in some 3/16" and slipped it between the arm and the body and tried the shop press. Pushed it right through the plate. Plan 3 made a home made puller with the thickest plate that would fit between the arm and the body 1/4". Useing a 1' cheater pipe on the end of a 1/2" breaker all I did was bend and stretch the 1/4" plate the tool was made from. I don't want to try heat because of the new seals and such. I don't know what else to try.
      Sep 2007
      Southern California
      Have you tried the special pitman puller you can borrow from Autozone? It is a heavy duty puller specially made for the pitman arm.
      I put some anti seize on the threads and used an impact. Spray the pitman arm with WD40, or liquid wrench. Go slow, get it tight and tap the side of the pitman arm with a hammer, tighten it a bit, hit with a hammer, tighten it one more time again hit pitman arm with a hammer. Loosen and repeat until it comes off. Took me two tries with this process to get the original pitman arm off my 68.
      Good Luck
      Jon
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      Another thing is to apply pressure with the puller and then hit the side of the pitman arm with a hammer. You would be surprised at how much that helps.
      Feb 2002
      Springfield, MO
      Grinder, cut off wheel and new pitman arm! Works for me!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Dallas TX
      Quote Originally Posted by shmoov69 View Post
      That may be the way I have to go. With full pressure on my tool and beating the arm with a small sledge it has not budged.
      Houma, Louisiana
      Thats what I had to do rather then risk ruining the box, the cut off wheel did the trick.
      Bill
      Jan 2002
      Italy
      IAs I understand it its stuck on the steering box, I'd preload the puller and bring out the torch, a new seal (if it fails) is cheaper than a new pitman arm.
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Dallas TX
      Quote Originally Posted by Tiger View Post
      Already have the new pitman arm. The one on the box now is wrong one for my car. I was sent the wrong one but did not realise it until I had already installed the wrong arm.
      Oct 2008
      Gearhead, use a small soldering tip on an acetylene torch. heat the side of the arm -about the size of a dime/quarter - not the whole arm and keep the flame away from the box. When it gets red try to pull it. Depending on the amount of heat, you may be able to save the seal. We use heat a lot in our shop to free stuck pitmans and haven't lost a box yet. It's just an obstacle, not a barrier - the cutoff wheel idea sounds interesting though - I may try it sometime. Keep those wrenches turnin', Dave
      USA
      Heat the arm ! ( Gently )
      It will expand and come off.
      Just don't heat it too close to the box.
      Jeff Tate
      U.S.A.
      Rowlett Tx.
      I don't care for those 3-finger style pullers.....
      This is how I've gotten them off in the past: Use a 'pitman arm' puller for 'pre-loading' the arm/box. Then add a little heat as described. W/the force applied by the puller, it usually takes very little heat on the arm to get it done (w/no seal damage).
      I've got one of the pitman style pullers if you want to give it a shot.
      west michigan
      Quote Originally Posted by ScotI View Post
      That's the way I usually do it. the pitman pullers are way stronger than just cold rolled plate.
      Dallas TX
      That for advise everyone. I tried one more time this time with a little heat and off it came.
