      Feb 2007
      Plano
      How much clearance?
      I dropped my motor into the car, LS1 with and H3 Oil pan, it barely clears. The oil pan is about an 1/16 of inch off the crossmember, so looks like i will have to shim the mounts somehow to yield more clearance. My question is how much clearance will i need? as anybody else ran into something similar?
      69 Camaro LS1 T-56, Corn is for making bourbon
      Oh it should self clearance if needed. Actually I do not think you will have problems.
      Feb 2007
      Plano
      Self clearance? not sure i know what that is?
      CHICAGO SUBURBS
      An oil pan should have more clearance than that. How much depends on where it's close and what type of mounts used.
      Feb 2007
      Plano
      I am sure you are right ...I figured people have run the H3 pan and S&P setup and would have had the same issue. Hoping for simple a answer...thanks for the replies!
      Henderson,NV
      Theree are no simple answers here. If you are running flexible mounts that probably won't cut it. I'd shim the motor up to a 1/4inch.
      Todd
      Self clearance was a bad joke just meaning the pan will dimple where it hits. Solid or poly mounts (or shimming) would solve that.
