    Results 1 to 17 of 17
      Mountain View, CA
      Cleaning the underbody
      My car was run for a while with a spun pan plug so the bottom is covered with oil. There is also the usual dirt, what's left of the OE undercoating, and the results of some very "enthusiastic" greasing of the rear U-joint.
      Anyone have a clever way of cleaning the bottom of a car w/o dragging it somewhere to put it on a lift and pressure wash it?
      Right now it's on jackstands in the garage with no front suspension.
      True T.
      My blog
      propane torch and a putty knife in a few different sizes, makes short work of old under coat etc, then wire brush/da sand etc
      before sandblasting on the rotisserie i always use propane torch and heat and scrape undercoating off, then blast it perfect clean.
      Mountain View, CA
      That part is pretty simple. It's the grease/oil that I'm confounded by. Other than a lot of soap/water (messy while sitting in my garage, and I don't relish the idea of sending that down the driveway and into the gutters and storm drains) what else would work. Is there a quality spray/wipe product that will do a good job?
      Simple Green and elbow grease I suppose huh? But I'm worried that the simple green might leave behind detergents that might screw up the bonding of any future undercoating.
      True T.
      My blog
      I can't recommend my solution: I cut all mine out and sent it to Nova heaven.
      Seriously, I'd use brake parts cleaner. I don't know what to tell you about putting some hydro-carbons into the storm sewers. I think you'll just have to find a way to live with yourself afterward.
      As far as bonding of new under-coating, just be sure you wipe it all off with pre-paint cleaner. It's lousy work, especially while on your back.
      jp
      jp
      ​John Parsons
      clean it with simple green, then go to autobody place and get some wax and grease remover, and wash thoroughly, it has alcohol in it so it drys very quickly. after that you should be good for epoxy, etc
      Feb 2007
      Plano
      I used a gallon of water based degreaser and pump sprayer...that stuff works pretty dang good. Got it at autozone and it comes in purple jug cant remember the name.
      69 Camaro LS1 T-56, Corn is for making bourbon
      Huntington Beach, CA
      You can make a catch mat with a tarp or something to catch all the nastiness and then at least send it to the dump rather than storm drains...
      Here is some inspiration lol...
      Quote Originally Posted by hotrdblder View Post
      clean it with simple green, then go to autobody place and get some wax and grease remover, and wash thoroughly, it has alcohol in it so it drys very quickly. After that you should be good for epoxy, etc
      simple green and elbow grease
      Jun 2008
      go get you a cheap drop cloth and two or three cans of easy off oven cleaner best degreaser in the world cuts dirt grease and oil off every thing. then take a torch to the undercoating. good luck with the scraping.....
      Mountain View, CA
      Quote Originally Posted by Chad-1stGen View Post
      Jeezus!
      Do we have a Darwin awards thread here?
      True T.
      My blog
      savannah,ga
      Just dive in and get filthy, maybe Mike Rowe can lend a hand. Accept the dirt as payment for a clean under side, probably a lot easier to clean with a lot of oil on it anyway.
      Quote Originally Posted by Damn True View Post
      Jeezus!
      Nah. Not only is that a stripped shell which is pretty light but it's supported by the boards which are bolted to the unibody and it's supported by chain to the garage rafters. It's a good alternative to a full blown rotisserie IMO.
      Mountain Springs, Texas
      I use cheap hardware store paint thinner to cut the grease. You can spray it on or brush it on with a large paint brush. Let it sit for a minute or two then scrape with a plastic putty knife (or a metal one if needed). I then follow up with a wax and grease remover to get the last of the film left behind. SPI sells a good solvent based wax and grease remover that doesn't cost an arm and a leg.
      Wear a respirator.
      Don
      Nov 2004
      Dallas Texas
      cleaner
      D/true- try some Easy Off oven cleaner spray it on and let it soak it will take alot off - messy and nasty wear a clean suit/goggles
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Dec 2008
      Toronto, Canada
      I used lacquer thinner, rags and a wire brush to go from this:
      To this:
      Well, that and rattle can paint. Technically I used "Gun Wash" which is a cheaper (recycled?) type of thinner.
      Jeremy Wilson
      1969 Ford Torino GT Fastback
      Marshall , MO
      If it was drivable take it to one of the touch less automatic car washes and get the under carriage wash. That will get the big chunks off.
      Brad Shepard
      69 Malibu
      Marshall, MO
      westchester county new york
      When I degrease something I use the heavy stuff first and then rinse it with some kind of hot soapy blend and use paint brushes to whisk it away.The degreaser or easy off gets the heavy stuff and then the soap and hot water wash all the ugliness away.
      Or make a parts washer out of an old above ground pool and a tanker truck of gasoline...maybe not.
