      Lees Summit, Missouri
      Welding fuel tanks??
      Any suggestions?? I am doing work on a '55 Chevrolet, it is a newer tank, but has a small leak around the sending unit. It may require a small weld. I have been told several ways to do this (I may just send it out to have it done for safety reasons), however I would like to know your thoughts. If I can keep the repair in-house, that would be great. I just don't want to lose any limbs on this project!
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
      May 2002
      Northern California
      Yes do be carefull. I've welded several tanks in the past with no flashy events. But that doen't mean you won't. I pull off the sending unit, I drain it well, let it sit a couple hour then fill it up with water,and flush it out. Then I rubber band the trigger on my air nozzle and stick it in the hole where the sender was and blow it out for a half hour. Then its usually safe to weld. I use to stick a shop vac hose in the filler hole while I welded the tank but don't do that anymore.
      After im done with the repair I add some Berrymans B12 to the tank when filling it. BE VERY CAREFULL AND MAKE SURE THERE IS NO FUEL VAPOR REMAINING.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Quote Originally Posted by MrQuick
      Thanks Vince, I will be very, very careful.
      Later - Craig
      [email protected]
      Central CA USA
      I fill with water with the weld area at the top, this leaves very very little air space to cause an explosion. Leave something open, like fuel sender removed for venting of the remaining space. It's overkill but I don't weld tanks a lot and want to be safe. People sure stay out of my shop when they see me welding a fuel tank!
      You can also epoxy or solder the area if you solder with something other than an open flame.
      A friend of mine did it the way David said. It ignited and changed the shape of the top of the tank, no injuries though. I thnk it is worth sending out.
      Albuquerque NM
      I had rock Valley do my tank. They did a great job. If its a small crack
      JB weld might work.
      Tom
      Central CA USA
      I should add, I rinse and vent first as Vince does. Another good idea I heard is to run a hose of inert gas into the tank (like CO2 ) and let it run on low while you weld.
      Nov 2004
      Roanoke, VA
      Connect one end of a piece of hose to the exh pipe of another vehicle then connect the other end of the hose to the filler neck on the tank. Start vehicle and let it idle for ~20min while exhausting into the tank, shut vehicle off, disconnect hose from tank, weld hole, done.
      Of course the above is assuming you drained any excess fuel out first.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
