      dash & turn signals
      Hey guys, I just got my 67 rs camaro back from the paint shop and now my dash lights doesnt work and both left and right rear turn signals blink when I turn the left signal on. The rear signals on the right seam to work fine and the front work but the front parking lights doesnt come on but the front turn signals work. I have checked the grounds. Any ideas? Thanks in advance for you help!
      Oct 2007
      MarshvilleNC
      Im having the same problem, well simialar I guess. My headlights, brake light and turn signals work. But my dash lights wont come on and when I try and turn them on the only thing that comes on is the turn signal lights come on and stay on and I can dim them and all like the dash lights should be doing. Any ideas? DId you get yours figured out?
      Casey
      Rockford Illinois
      Redo all of the ground wires. It is common to have these poblems once they have been removed and replaced with the old connectors. If it isn't your ground wires You will probably see what is when you are inspecting for your grounds.
