Results 1 to 11 of 11
Thread: Polished Wheel Durability
11-15-2008 #1
- Feb 2007
- USA, TN
- 850
How long does the polished shine hold up on a wheel like the Bose or Rushforth's? Do I need to clear coat them to keep them looking good? Also, how hard is it to re polish them?
11-16-2008 #2It depends on a ton of variables but I'll try to help shed some light on things that will knock down your polish faster. Some are obvious and others not as much.
The biggest polish killers include daily drivers, un-garaged storage, driving in the rain, driving in harsh winter conditions, living where they salt or gravel the roads, living near the ocean, letting the car get filthy before you wash it and using the same unrinsed mitt to wash the wheels that you just used on the rockers, hard water, harsh wheel cleaning chemicals and aerosol "No Touch" tire dressing left too long are the biggest ones that come to mind. I'm sure any good detailer can add a bunch more. If you don't do any of those things, you can leave the wheels alone for a year no problem especially if you throw a quick coat of wax on them the day you get them out of the box and use care when cleaning like using fresh soap and mitt for just the wheels and seperate soap and mitt for the car. It sounds anal but a little step like that will noticably prolong the time between polishings. And when they inevitably get dull, you can call us years down the road and we'll give you suggestions for product and advice for easy polish techniques.
Our brushed and cleared centers have become our most popular finish and makes the centers virtually maintenance free which only leaves the outer rim to be polished which is pretty easy since the valve stem is on the inside and you can even brush the entire wheel if you aren't crazy about the polished look.
Finally, if your car sees some harsh conditions or you truly hate the idea of polishing, we can clear it with a non-powdercoat process that is much clearer than powder clear and holds up just as well.Jason
11-16-2008 #3
- Nov 2006
- Cincinnati Ohio
- 1,060
