      Aug 2005
      Patterson, NY
      Which throttle body to use?
      I have a 409 ci small block that may occasionally see 7500 rpm. The intake will be the Edlelbrock Super Victor EFI manifold.
      I have a stock single blade (LS1 style) throttle body from a GM Ram Jet intake, which I suspect is too small for my combo. I asked Edelbrock and Accel for manifold and throttle body recommendations, and Edelbrock recommended a four barrel type, 1000 cfm throttle body, while Accel recommended a three barrel, 1350 cfm throttle body.
      What do you guys recommend?
      What are your thoughts on my choices?
      TIA!
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by GetMore
      TIA!
      I had a 7500 rpm 406 with an 1100 cfm 4 barrel tb and it still pulled vacuum at wot, so it was a restriction, too small for the combo. The three barrel should flow more and work pretty well. I like the 90 degree Wilson adaptors and monoblade tb's for looks and performance, but it'd take bigger than 90mm to flow enough in your case. I think an aftermarket 90mm tb is about 1150 cfm, which may not be big enough.
      Jody
      Aug 2005
      Patterson, NY
      That's the kind of info I was looking for. Thanks!
      As fas as I know Edelbrock doesn't have anything larger than 1000 cfm, so that explained their recommendation.
      I really wasn't planning on the 90mm unless it worked out to really be the best. With the four barrel style I get to do the cowl hood thing for a reason other than looks.
      Indianapolis, IN
      Wilson Manifolds also has a dominator style throttle body in three version and flow up to 2000+ CFM. The middle version at almost 1500 CFM would probably work for you. I am a dealer for Wilson so just let me know if you need a price or more info.
      Then we have billet LS style TB's up to 115mm if you decide to use an elbow like Jody mentioned.
      Hope this helps.
      Mike Norris
      Mike Norris
      Aug 2005
      Patterson, NY
      Unfortunately, the intake I think I'm going to use has the 4150 flange on it, not the Dominator/4500 type.
      However, I'm open to suggestions and any options for my setup.
      The heads are Bowtie Vortec 180s, with some light porting done, so whatever intake I use needs to match them.
      I'm not sure I'm willing to spend $2500 on a custom sheetmetal intake, but if you've got something more reasonable I'm all ears.
      Is there any advantage to using an LS style TB with an elbow?
      Indianapolis, IN
      I think the 4150 TB from Wilson is just under 1200 CFM. They do make an adapter to put a 4500 onto a 4150 flange that is 1.5" tall with and without a burst panel. Thay also offer a service to weld a 4500 flange to the 4150 manifold and will add approx 1" to the height of the manifold.
      Just a couple less expensive options. The Accell three barrell is a good option also.
      Mike Norris
      Mike Norris
      With small vortec heads the TB choice is not as critical since they will limit how much flow and how many rpms the engine can use.
      70 Mach I, dry sump & lots of mods
      70 1/2 Z28 project car
