      Apr 2008
      Nascar cup style steering column?
      Anybody here running the nascar style steering columns. Just wondering what it takes to install one?
      a drop bracket for the dash, a custom plate for thru firewall with a thru bearing installed.
      Jun 2009
      Katy, TX
      i used the thru firewall bearing, mine looks kind of cheap, i should have shopped around a little more
      for the support I bolted a piece of 1/4" to the original support and in a hiem to hold the shaft, make sure you get a hiem joint made for this (slightly oversized) or it will freeze up on the shaft, I think speedway had them
