Results 1 to 10 of 10
Thread: headlights cause voltage drop!
11-09-2008 #1
- Aug 2004
- San Bernardino, CA
- 883
im having electrical problems since the install of my carbed ls1. here is a thread i posted on ls1tech about my electrical problems.
http://www.ls1tech.com/forums/showthread.php?t=994010
any help would be appreciated.
11-10-2008 #2I'll bet relays for your headlights would help. Take your current feed wires and make them the open/close circuit and run direct alt power to the load circuit.
11-10-2008 #3
- Aug 2004
- 883
i thought the painless fuse block had built in relays for the headlights? or would i need to add more?
im wondering if i have a crappy reman f body alternator. im currently on my second alternator. do you think a 130 or 160 amp would be better?
with just the fuel pump running while the car is warming up best i get out of it is 13 volts. i never had these problems when my gen 1 small block, but then again i wasnt running an electric fuel pump either.
11-10-2008 #4
