      Arlington Heights, IL
      power steering fitting question.
      I bought the DSE power steering hose kit to go with my lee steering box and gm type 2 pump but i messed up one of the fittings. Im wondering if i can go get a -6 AN fitting or if i have to use one of these. http://detroitspeed.com/productpages...tting_prod.htm
      Its the fitting that comes from the top of the pump to the box.
      thanks
      Jesse
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      Auburn, WA
      It doesn't have to be 90*, but it does have to be a fitting to accept the common teflon-lined hose, which are rated for much higher pressures than the standard braided stuff. Most hydraulic shops should have them.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      LI New York
      This fitting will work if you have a saginaw pump. http://store.summitracing.com/partde...5&autoview=sku I know someone sells a 3/8 to 6AN , but I cant find it.
