      Fullerton, CA.
      Unisteer R&P A-body install
      Ok, this is for research and final comparison, so if you have suggestions on what to compare/test for baseline I'd really appreciate it.
      My Chevelles front end has been completely rebuilt and has 1500 miles on it and I'm currently using a Delphi 600 series box and Sc and C stage2 kit with Eibach springs.
      Now Unisteer has asked me to install one of there Rack kits for comparison to the delphi 600 box, since most of the conversions are from either a manual box or an old worn out 800 series, so they would like my feed on how it compares to a 600 box.This may have already been done, but hey it's all for research/feedback. Now I know that there has been constant debate between a great steering box and Rack and pinion, so here's a chance to post those concerns/opinions and issues. Also, if Mark from SC and C can chime in, any input would be greatly appreciated.
      Mike Martin
      Heavy Chevy 2.0: 71 Heavy Chevy, Unisteer,SC&C, GW,Eibach,Bilstein,Helwig,Showwheels-Streeters, Carb'd LS-327 W-200-4R
      LS-327 powered, Atomic EFI on the way
      Sep 2008
      Kathleen, GA
      suscribing for info...
      free cool
      May 2008
      SoCaL-Pico Rivera
      Maybe when you are done with their rack you can send it my way. Gave my sister 10/k as she lost her job to our lovley California budget. Shes a teacher for LAUSD. That was my projet build mpney and well would like to keep the project moving.
      Fullerton, CA.
      Who knows, maybe I'll like it and go over to the dark side
      No really this is for research and I'll post pics and list any issues and solutions with the install. First I will have to drive the car like I stole it and take note on how the car feels with the box and then after the conversion, drive it again through the same course and compare notes. I don't have any preconceived notions or likes/dislike between the 600 box and the rack and pinion. Don't get me wrong the 600 box SMOKES the old 800, but I must say I am curious on how the rack will compare.
      Mike Martin
      Fullerton, CA.
      We'll I have started the install, but have run into a few minor snags, but nothing major. I received 1 wrong U-joint (1"double-d instead of a 1" splined) and the the pump they sent has a single groove pulley which interferes with the Alt. belt. NOTE: Long WP installations will do better with a double groove pulley as it's used as an idler for the Alt. Belt. or the A/C Compressor if your running OE brackets. As for the rack itself the install is a breeze, in fact you will spend more time removing the old steering components than actually installing the rack and pinion. It's well engineered and thought out. I'll post pics as soon as I get them edited. Unisteer is sending me the correct U-joint and pump since the pulley is pressed on and I don't have the proper tool to change it.
      Mike Martin
