Results 1 to 20 of 20
Thread: Water in valve covers?
I have a SBC 400 bored .040 over with 882 heads, new crank, pistons, rods, bearings, everything is new. I have about 2,000 miles on the motor. I noticed that I had a little oil in the radiator. So that was an excuse to buy a new aluminum radiator. ( when the motor was out the radiator and hoses were exposed) I know that only transmission fluid goes through the radiator, I just thought maybe when it was outside waiting on the engine, the radiator may have gotten oil or degreaser in it. So I just installed the new radiator and flushed the system. There is still a little oil at the filler neck but it may be residual. But just out of curiousty I pulled the valve covers and there is a bunch of frothy oil/water in my valve covers. I cleaned it all up, ran it 2 miles and it has water in the valve covers again. There is NO water in my oil pan though. Any ideas???
10-28-2008 #2Also the steam holes are drilled in the heads...
10-28-2008 #3i had a similar problem with my head studs leaking. it seems that on my BBC, the studs go into the water jackets, and weren't sealed well enough. i found the ones which were leaking, pulled them, used thread sealant, torqued the heads back down, and it stopped. just an idea...
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
wir müssen Leben bis wir Sterben...
10-28-2008 #4Thanks for the input, easy enough to try..
10-28-2008 #5where in florida are you from...
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
10-28-2008 #6
