      Ft. Worth, Texas
      Very urgent. Please respond.
      Hello. I have several questions regarding suspension options for my 1969 Camaro. The car will be a wicked road race machine that will be able to be driven on the streets, and I was wondering what suspension components I should use to give me the firmest ride without sacrificing a lot of ride quality. Also, I was thinking about installing a Chris Alston Chassisworks front subframe, but a lot of pople have told me that this is a bad idea because it is not much of an improvement over the stock stub. However in the Classic Industries catalog it says "The Alson's front subframe is a complete assembly that utilizes lazer-cut, CNC precision bent steel that has been fixture welded for precise fit. This also creates a much lighter and stronger frame. Plus when I called Alston's, they said that the front stub is 80 pounds lighter than a stock frame? Should I just say screw it and stick with a stock stub? Here are the parts I am considering-
      -DS&E Speed kit #3
      -DS&E rear mini-tub kit with 3" drop.
      -Hotchkis 2" drop coils
      -1.5" drop spindles (Any suggestion on type?)
      -Koni Coilovers
      Or I may just end up doing either a Global West Cat-4 or CAT-5 system. Please give me some advice. I get advice from all aspects, (very helpful) but I never get a definate answer as to what I should use.
      CA
      Which components to get is up to you, but I'll give you a couple of advices.
      Get everything from a single company. If you get a kit from DSE, stick with their springs (or the spring rate they recommend). If you do CAT-5, get spirngs, shocks, swaybar from GW. If a company fails to recommend spring and swaybar rate based on your combination (engine, tires, etc), go elsewhere.
      Suspension needs to be designed as a system, just like an engine. Mixing parts from various manufacturers isn't a good thing unless you really know what you're doing.
      Stick with stock subframe for now. It can be modifed good enough to satisfy 98% of people. Also if you really start doing wheel-to-wheel racing, aftermarket sub may not be allowed by rules.
      If you ever decide that you need to improve handling further, you can always sell your modifed stock sub.
      The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
      Signed,
      A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
      dennis68 Guest
      Joker....this is the 3rd time a post has been started about the same thing on the same car witht he same goals. Are you looking for different answers by rephrasing the question?
      I think we covered the Alston sub issue 2 threads ago...
      What does any of this have to do with making it handle better. I wouldn't care if it were laser cut, plasma cut, good old fashoined cutting torch cut or cut with a die grinder and a 4" cut-off wheel. It really has no bearing on whether or not the geometry has been optimised for your intended purpose.
      I would rebuild the stock sub , do some tricks to improve geometry (g-mod), rebuild with new steering and suspension and get a feel for what it does now before attempting to build "Big Red".
      Everybody wants a track car with license plates but it doesn't do any good if you don't know how to drive it, it is much easier to learn in a street car than a race car.
      Abbotsford, BC
      Is there a search button here??
      1966 Volvo
      Mar 2004
      Mid-Michigan
      Quote Originally Posted by thejoker21
      [b][font=Arial]Hello. I have several questions regarding suspension options for my 1969 Camaro. The car will be a wicked road race machine that will be able to be driven on the streets, and I was wondering what suspension components I should use to give me the firmest ride without sacrificing a lot of ride quality.
      Joker,
      If the above quote is your real intent you should determine what sanctioning body/class your Camaro will run in and build it according to their rules and guidelines. Many aftermarket parts are not legal for sanctioned racing and it would be very sad to see you finish a car that you can't race...
      And this is just my input here but "wicked road race machine" and "ride quality" probably don't belong in the same sentence together...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Oct 2003
      Arvada, Co
      Yes the search function works, but sometimes there is operator error.
      Brian
