    Results 1 to 17 of 17
      Sep 2008
      Ok
      SPC A-body lean and pull
      Hi, first post here. I just installed the Stage II+ kit from SC&C into my 67 GTO. I have a couple of issues after the install. My first one is that the car is 3/4 inch lower on the left side now than the right. My second The specs from the allignment are as follows:
      Left / Right
      Camber 0 / 0
      Caster 2.9 / 2.3(or 3.2 according to the shop)
      Toe 0.08 / 0.05
      This is the best the allignment shop could do. These are the specs from the sheet the machine printed out. I am going to install some shims to raise the front about an inch because the kit is just a little too low and I hope it will cure the lean. Can anyone see something in the allignment that would cause the pull? The tires are brand new and the inflation pressure is the same. Thanks for any help.
