      May 2008
      20inch wheels on a nova
      Hey guys my 69 nova its just about done from the body shop and next i will be purchasing my wheels and tires. The car has the DSE minitub kit on it. I want to run 20inch wheels front and back but everyone always runs 20/18 combo or 20/19 combo why?. If your going to run 19s up front why not just go one more size up and run 20s.Basicly I want to now if i can run 20s in the front with out any problems. I want to sit just like my BMW I just love that european look
      It's kind of apples and oranges but let me see if I can explain it as a stylist and wheel manufacturer. The staggered look comes from hot rods and supercar styling like Ferraris, Carrera GTs, Vipers, Corvettes and smaller cars than your sedan because the front wheelwells can't handle as much width and diameter as the rear and still sit low at all. If you plan to stuff 20s in the rear, it's really recommended that you stagger them to get the car down low and turn without issues especially with the square cut tops of the wheelwells in a Nova. That's exactly where they will rub when you turn and if you look at the basic profile of a Nova or most musclecars, it's more like a sportscar than a sedan. Long nose, short deck, even a fastback rear window in the Nova and the low cut rear wheelwells that really lend themselves to staggering the diameters unless you run a diameter that will fit in front like 18s or 19s and then it will work all the way around. A sedan like your BMW or a Mercedes sit more level and have similar sized wheelwells in front as the rear for a very balanced look.
      Let us know if any of our styles appeal to you and we can make suggestions or recommendations and build a set that fit just right.
      www.RushforthWheels.com
      Jason
      San Diego, CA
      In addition to what Jason said, there's also the eye tricks that happen when you run staggered heights. On a newer sedan you run the same tire height all the way around with the same size tires. That looks doesn't work as well on the older cars. Therefore if you run 20's with a taller tire on the back and a shorter tire on the front, you have more sidewall on the back. This gives an optical illusion that your rears are actually smaller in diameter than the fronts, even though they are actually the same. Thus if you stagger them, it looks balanced.
      Dec 2007
      Carlsbad, Ca
      what those guys said.......
      look into the tire sizes most guys are using and youll see what they mean. for me, its a 28" tall rear tire and a 27" tall front. in order to keep the same sidewall im running a 19/20 combo.
      Tim
      Tim
      Build Thread Link
