      Calgary, Alberta, Canada
      Replacement Tires - 2000 WS6
      The factory Goodyear tires on my 2000 WS6 finally wore out at 50,000 kilometres (30,000 miles). Soft compound and rather aggressive driving style, I guess. I'll replace them over the winter. Any recommendations for the new ones? I'm looking for maximum performance with a factory sized tire (275 R40 17) ; The car is never driven in snow, buty occasionally sees rain. I read that the BFG G-gforce KD's are no longer the hot ticket. I wondered about Kumho and Bridgstone. Any informed or experienced opinions appreciated. Thanks!
      Steve
      1978 WS6-W72 4-speed Trans Am: Fire-Am Restification Project
      VSE front and rear sway bars, solid spherical control arm and spring eye bushings, front springs trimmed 1/2 coil, VSE aluminum oil pan and baffle; Pro-Touring F-Body solid aluminum subframe bushings, 1980 WS6 rear disk brake system, 12" 1LE front disk brakes, Alston cowl-to-subframe Y-braces and subframe connectors, Moser axles, Hooker chrome roll bar, Corbeau GT-8 seats.
      2000 WS6 Trans Am M6
      Feb 2003
      Houston, TX
      BFG KDW2 (flame looking tread) are still my favorite on street cars. They work well in the rain, have deep treads, look killer.
      For a little better performance, I prefer the Nitto INVO tire. Good in the rain, but not much tread depth and they probably won't last long.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Jul 2008
      Bethlehem PA
      I just ordered Goodyear F1 GS-D3's in that size.
      My car is not driven as much, so treadwear is not a big concern.
      In most cases, increasing treadwear will cost a little in performance.
      Aug 2006
      Cibolo, TX
      I like Vredestein "Sessenta" tires. They are a Dutch tire. I have a Dutch wife, so I guess I am partial to Dutch stuff.
      www.vredestein.com
      www.groupawheels.com
      www.performanceplustire.com
      They are available in 275/40/17s.
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
