      Apr 2007
      New Jersey
      Accel DFI wiring - will not start
      So I did something wrong but where to start to troubleshoot
      New harness, new DFI system, new everything.
      I just phased the distributor so it has power, the Accel 6A box has a red light on the diagnostic port so it has power but when I turn the key
      Nothing
      Starter does not engage.
      Where is the best place to start tracing it back?
      Thanks everyone
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by thedugan
      Nothing
      Thanks everyone
      if the starter won't engage that's your regular car harness not the efi harness. First thing to check is the neutral safety switch; is it hooked up and adjusted correctly? This assumes you have the two wires to the starter on, red 12 volt cable and the start wire on the solenoid, the purple (on most GM vehicles) wire that comes from the ignition switch to the starter (while going through the neutral safety switch).
      Jody
      Apr 2007
      New Jersey
      Jody your the man.
      That was it.
      Neutral safety was not hooked up. So I hooked them together and it cranks.
      Your Awesome.
      Doug
      Aug 2001
      Jody your the man.
      That was it.
      Your Awesome.
      Doug
      glad it helped.
      Jody
      Apr 2007
      New Jersey
      Let me make a killer hidden kill switch
      Aug 2001
      yep, good use for one. Just make sure it's not a super cheapy switch that can't handle the amps from the starter during cranking.
      Jody
