      Mansfield Texas
      Dumb question for the experts.
      Due to what seems to be a incredible deal on a LS2. I need to know what else will be needed to put it in my 67 Camaro along with cost estimates. I'm gauging the cost impact on my project. I'm sure this has been discussed on here for years so b nice. New thought for a rookie
      Phoenix, AZ
      easy you need motor mounts, harness, computer, headers and tranny, depending on what oil pan and sub frame you have you may need to change that out. If you go after market on the computer you will need tranny controller unless you have a stick.
      Are you getting a block only or ready to run set up? you will need pulley system as well if block only
      Chris Fesler
      Midwest
      Don't forget the front accessories... you may need to swap some stuff to make it fit in your car.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Mansfield Texas
      Long block assembly
      computer not included. Wiring harness available for it.
      Felton, DE
      http://www.ls1tech.com/forums/showthread.php?t=472609
      Just about everything you need to know to get you started
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Mansfield Texas
      Great info.
