    Results 1 to 18 of 18
      Phoenix, AZ
      '67 Camaro Running Hot
      I know this has been brought up numerous times in the past, but the details are a bit different than other posts, so I'm hoping the collective knowledge here can help me out:
      My dad has a '67 Camaro with a relatively mild 396. The engine has approximately 3k miles on it, same as the water pump, radiator, etc. The engine has the March pulley system, and a dual Flex-a-lite (pusher) fan.
      The problem we're running into is that the car is perpetually running hot. Whether it's January or July, we regularly see upwards of 230 deg in stop and go or freeway driving, and typically higher (up to 250). My dad is planning to just start throwing money at it, but I'd like to have a better plan than that. Are there any recommended first-start areas? FWIW, the t-stat is working properly, the pump "seems" to have reasonable flow, and the hoses are getting hot as expected during warm-up. Any other ideas?
      As always, the help is appreciated.
      ~ Jason
      Jonesboro, Arkansas
      Has the BB always been in it? If not maybe the radiator's too small. Wow Phoenix, it's always hot there lol. Has the radiator been on the car for a long time? If so, it may need to be cleaned (inside) by a radiator shop. Just a couple of ideas..
      Henderson,NV
      Pusher fan is what stands out. You need a puller fan.
      Todd
      Jul 2007
      Tracy, CA.
      Quote Originally Posted by Vegas69
      Agreed! what is the radiator? maybe go to a nice aluminum radiator with twin puller fans.
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Apr 2008
      Country Flag: Sweden
      Check the timing. A friend of mine solved this issue by set timing correct. I admit I was sceptical, but that was it...
      http://www.camaros.org/forum/index.php?topic=2648.0
      Phoenix, AZ
      Thanks for the replies. Agreed on the pusher fan not being an ideal setup, but at the time of purchase we couldn't find anything that would fit on the puller side without contacting the pulleys. Looks like we'll start with the timing issues, and then re-visit the fan setup. Will post an update...
      Henderson,NV
      I don't think there is any way a pusher fan will cool a big block. I can barely get twin 11 spals that flow over 3000 cfm to cool mine. I need to dilute my coolant and run some water wetter. 600hp here.
      Todd
      Jul 2007
      Los Angeles, CA
      Definately on electrics you need a puller fan setup. Spal makes some of the best electric fans. If you are contemplating redoing your cooling system check out:
      Big time cooling for Big Blocks!
      Phoenix, AZ
      Definitely appreciate the responses. The only thing complicating matters slightly is that the car is en route to be sold, so we're trying to stay away from a wholesale redo of the cooling system. I think at this point, the plan is to re-confirm timing, etc. (gotta do the free things first), and then probably look to the Spal push fan. Again, thanks for the feedback, I will let everyone know what we find.
      Sep 2008
      There is no question in my mind that it is the pusher fan. My brother recently put a 502 in his 67 Camaro with I am assuming the same March pulley system. He had to buy a BeCool radiator with dual fan setup. Cools fine and we are in New Mexico. I think it cost him approximately $ 1100.00. I know its not the news you are looking for, but I am confident this will fix your problem.
      Newbury Park, CA
      Before throwing any money at the car the accuracy of temperature gauge needs to be verified. These things are notoriously innaccurate. Often a resistor pack must be used to tune the guage properly.
      Phoenix, AZ
      Definitely appreciating the feedback. The timing was not an issue, so it's on to the next steps:
      1) Confirm temp gauge accuracy - I will pick up an IR gun and check that tonight.
      2) Look into a puller fan - The only problem with a puller fan (and the reason for the pusher fan in the first place) is that we only have 2" between the radiator and pulleys. Do other people have this type of problem? I am wondering if we have a screwy radiator (dimensionally), and if that's creating all of these problems in the first place.
      Thanks to all for the help.
      Henderson,NV
      If selling...how about a good ol fashioned fan blade and shroud.
      Todd
      Miami
      have you tried taking the tstat out and running it to see how hot it gets then?
      Henderson,NV
      That's just going to delay the inevitable.
      Todd
      Phoenix, AZ
      I like the idea of the engine-driven fan, but the reason for the March pulleys in the first place is that we only have about 2" from pulley to radiator, and couldn't get a fan clutch, etc., to fit in that tight of confines. So, we were left with the pusher fan as the only alternative at the time. At this point, I am wondering if we have a goofy radiator, or something like that, and that is why we have so little clearance. Has anybody had this problem also, or is everyone running >2" (snide remarks aside).
      Thanks again.
      ~ Jason
      Henderson,NV
      Take a photo. What about a flex fan. I wouldn't use one but your selling it. That should fit in two inches with a very small spacer.
      Todd
      Newbury Park, CA
      If using an IR gun be sure to use it on an area that is dull in color. IR guns will have a huge error if used on shiny surfaces.
      I use this test as an example during customer training and non-believers. Heat a shiny metal surface (I use a bearing ring) using a temperature paint stick and an electronic temperature probe as a master gauge. Wait until the paint melts and shoot with the IR. Now do the same thing but spray some cheapy flat-black paint on the same surface. The shiny value will be 30-40% lower than the flat/non-glossy surface.
      The paint sticks can be found at Graingers, Mcmaster Carr, etc and only cost a few bucks each.
