      Waukesha, WI
      Clear coat question???????
      I have done a bit of my own painting, but I am no expert. I want to make the clear coat on my BLACK Marauder look better than new. It is in good shape but has lots of wash mit marks and fine scraches in the clear. Yes Factory paint no redoes on it. What are the best was to make tha black look 10 miles deep? If only light scratches is buffing enough or should I do a light wet sand on it first? What girts and then what buffing stages? Thanks
      2004 Mercury Marauder 5.0L Stroker and NOS
      1968 Fairlane 347 Stroker--soon to be PT style
      1973 F-100 lowered
      1957 Ford Wagon, project
      Mountain Springs, Texas
      I would try this method omitting the wetsanding and starting with the cutting cream and the black wool pad. It removes small scratches quite easily. You could also try skipping the cutting creme and see how it looks and back up to the cutting creme as necessary.
      http://www.southernpolyurethanes.com/Easy%20buffing.htm
      You can buy these Presta products on ebay.
      Don
      Waukesha, WI
      Quote Originally Posted by dhutton
      Don
      Thanks Don!
      1973 F-100 lowered
      Forgot to tell you to be careful with your edges. You should probably run masking tape along them until you get the hang of it if you have never done this before.
      Don
