      Phoenix,Arizona
      One Glowing Header Tube????
      Hey guys,
      Here is the situation; I just built a brand new engine (sbc 355) for the Nova. Went to break it in and after about 5 minutes of running it at around 2500rpm to break in the cam i notice that the header tube on cylinder #5 is glowing red hot. None of the other cylinders are glowing. What could cause this on only one cylinder? Also i noticed some white residue inside the tube when i removed the header. Any help is greatly appreciated.
      Brian
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Tallahassee
      Maybe the exhaust valve isn't fully seating and is allowing the combustion into the #5 primary tube?
      Sep 2002
      San Jose, CA
      maybe you lost a cam lobe during break-in
      I would pull valvecovers and crank the engine around once by hand to see if the #5 valves are opening and closing properly
      Just call me Brett
      Phoenix,Arizona
      yeah i thought of that too, i checked the rockers and they seem to be opening an closing properly. I just dont get why that one cylinder is doing it. Im gonna pull the plug tomarrow and see what it looks like.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Farmington Hills, MI
      Is it possible that you have your PCV hose to the port on the intake that is specific to 1 cylinder?
      I did this and it causes a lean condition in one cylinder, hence the glowing tube.
      PCV should be connected to a vacuum port that feeds all cylinders.
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Oct 2007
      ridgefield ct
      EFI or carb?
      Phoenix,Arizona
      its got an Edelbrock 750 on it. 10;1 compression. Aluminum heads, cam is 488/510 lift, 234/244 duration at .050", Hooker 1 5/8" headers, edelbrock performer rpm intake.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
