      Rural Retreat,VA
      March style track- ps pump
      I just installed my March style track serp. belt system and was wondering if there was a oem reservior that would fit the 87 sunbird style pump. I'm looking for a reservoir like is on the DSE pump...
      Thank you
      Keith
      Rural Retreat,VA
      Should I junk the March PS unit and buy a DSE pump with reservior attached?
      research these they may be what you need. Part stors sell a 5/8 power steering hose for a audi aplication...
      Check the hose barb sizes to see if they will work Moroso Mustang Power Steering Tanks
      [/img]
      oops reread your post and these are not what you want but I will leave them posted for others to consider.
      Pittsburgh, PA
      Does your pump have a female or male port for the tank?
      If it has a female, Canton Racing makes a pump mounted reservoir. They are pricey, but some of the only ones Ive seen.
      www.cantonracing.com Look under "tanks" & then "power steering"
      www.jonesracingproducts.com also lists an aluminum & plastic integral reservoirs, but dont offer much info.
      Shane
      PA.
      You may have another issue besides the reservoir. `87 Sunbird is a rack and pinion car. Their pumps run at much lower pressure and much higher volume than GM pumps for a Saginaw 800 or 670 steering box. Unless you`re running a R&P conversion AND it`s calibrated to GM r&p pressure and volume you may have a mismatch. It`s a very common issue. If you`re running a conventional box you`re looking for between 1300-1450 psi and 3.5 gpm. If you switch pumps make sure you ask. Mark SC&C
      Rural Retreat,VA
      I would hope that the march kit would have a modified pump?
      I think I will call March or Frank were I bought the Kit.
      Here is the pump.
      Keith
