    Thread: GTO Bushings
      Oct 2008
      GTO Bushings
      Hello. I'm new to this website and new to the restoration process. I am currently doing a frame-off restoration on my 68 GTO. I initially wanted to replace all of the bushings with poly bushings, but after reading several articles and visiting multiple forums, I am more leaning towards OEM rubber bushings. I was wondering if anybody could me find a reputable company with complete OEM rubber bushing set.
      Also, is there any middle ground between OEM rubber and Poly bushings? Maybe a more stiff rubber bushing not quite poly? Any help would be greatly appreciated. Thanks in advance.
      May 2000
      Have you tried asking at a parts store? I would think they could get rubber bushings.
      Jun 2005
      Manassas, VA
      The factory style bushings are available at all the resto mail order places, and I believe there are still GM once available. It's borken into several parts, like the core support bushings are different, you have to get the sleeves/collars, washers, and bolts separately.
      There is something in between, and it's slipping my mind at the moment, dura-something. Are you falling for the 'solid/poly bushing make for a harsh ride' thing? Don't believe it. It's so little of a difference you wouldn't be able to tell, and the benefits are much greater. Usually people also change things like tires & wheels, as well as stiff springs and shocks, al at the same time and then blame the bushings. Not. Case in point: New cars don't have body bushings, it's all one piece. (for the most part). My advise, go solid.
      HWYSTR455 on PY
      1971 Lemans Sport 461 bottle fed daily driver
      1971 Trans Am 474 blown EFI pro tour car
      1972 442 W-30 clone
