Thread: lt1/t56 HELP!!!
- Feb 2005
- 182
lt1/t56 HELP!!!
Hey guys,
First and foremost, I am not a mechanic but I have installed an lt1/t56 tranny in a 69 camaro. Here’s my problem, when pushing the clutch it is hard as the brake pedal. When I push the clutch pedal it barely moves and does not spring back. Has anyone had this problem? How do I fix it? I was told to bleed the clutch assembly but how do you do it? What else might be the problem? Any help is greatly appreciated!
khoult
10-08-2008 #2i had the same problem, and it ended up being my clutch fork was not in the right position. the clutch slave was pushing on the fork handle instead of the dimple on the fork. repositioned the fork and the clutch worked...hope this helps. good luck hearing from anyone else, it seems like no one here uses the LT1 T56.
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
wir müssen Leben bis wir Sterben...
